Installed Steering Wheel Controls and now no Speedometer
Old Apr 8, 2008 | 09:25 PM
SanFranTC's Avatar
Default Installed Steering Wheel Controls and now no Speedometer
I installed the PAC steering wheel control adapter with my Alpine HU yesterday and now the steering wheel controls work, but I have no speedometer and my Brake, ABS and tire pressure lights are on on my 2007 TC.
I am just wondering if there is a fuse or common ground for all of these that may have blow or gotten disturbed while I installed this stuff. The ground I used was on the left side of the dash opening just behind the guage cluster. There was an existing brown wire here attached by a bolt.
Thanks for any help, I would much rather not try to troubleshoot the problem if someone know from experience a specific fuse that would cause this behavior.
Old Apr 8, 2008 | 11:31 PM
BZinn1's Avatar
did you disconnect the battery before install........is not you probably blew the fuse for them........cars grounds are sensitive to change and like to blow fuses
Old Apr 8, 2008 | 11:52 PM
SanFranTC's Avatar
Sounds likely. Stupidly, no, I did not disconnect the battery. I will check the fuse for the guages first and if not that one I will check them all to see if I find the culprit.
Old Apr 9, 2008 | 04:56 PM
SanFranTC's Avatar
Turns out it was something even stupider than a blown fuse. In order to install the adapter I used an add-a-circuit device and the first fuse I pulled, which happened to be a costant 12v instead of switched, I put back into the wrong space. Instead I put it into an unused space on the fuse block. Needless to say the problem is now fixed.
Old Apr 10, 2008 | 12:50 AM
java09's Avatar
^^haha thats funny to me... glad everythings good now..
Old Apr 10, 2008 | 12:52 AM
azureloki's Avatar
did u do the pac install urself? i cant get it to work lol
fur_pig
Mar 20, 2020 04:28 PM
FurionAlpha
Scion tC 1G ICE & Interior
Jan 12, 2015 08:25 PM
toyotaisme
Jan 10, 2015 10:24 PM
Beesh
Jan 9, 2015 06:30 PM
armyrockmorales
Dec 28, 2014 10:39 PM
