interior dome lights problem
Old Aug 11, 2008 | 06:33 PM
JINeration's Avatar
Default interior dome lights problem
i have a problem with my interior lights they seem to go really dim or they dont even turn on same with my key hole light for my sterring wheel they all go really dim or not even turn on i need some help someone please help me
Old Aug 11, 2008 | 06:40 PM
sciontcguy69's Avatar
do u have a system in ur car? ( sub, head unit, speakers?)
have u done ne mods to the interior or lights that would involve any wiring or fuses?
Old Aug 11, 2008 | 07:30 PM
krazyscion's Avatar
probably u hooked up something that is drawing too much power from the lines of the lights
Old Aug 12, 2008 | 03:49 AM
JINeration's Avatar
is there a fuse for those lights inside
Old Aug 14, 2008 | 11:35 PM
JINeration's Avatar
okay this is really annoying me for the fact that i dont know what the problem is?
Old Aug 15, 2008 | 12:28 AM
RammsteinNicCage's Avatar
Can you answer sciontcguy69 or krazyscion questions? That might help people to help you. The dome light fuse is in the fuse box in the engine bay, it's a 7.5amp fuse.
Old Aug 16, 2008 | 10:13 PM
JINeration's Avatar
well i do have a system and i shouldnt have hooked nething up too draw more power
Old Aug 17, 2008 | 02:58 AM
Well, if the lights dimming is always happening, try unhooking your system for a little while, just so that you can definitively rule that out as being the cause.
Old Aug 17, 2008 | 03:53 AM
JINeration's Avatar
you mean the battery casue i already done that and it didnt help
Old Aug 17, 2008 | 04:17 AM
athlete3232's Avatar
not the battery? how could u see if it worked if the battery was off? disconnect ur system (amp/subs) to see if that was drawing to much power...
Old Aug 17, 2008 | 04:25 AM
JINeration's Avatar
lol sorry my bad i have that disconnected already cause i wanted to make my car lighter
Old Aug 17, 2008 | 04:26 AM
and their still dimming? than idn. i figured the amp would be tsking to much power.
prob the fuse, or maybe their not in right/good?
Old Aug 17, 2008 | 04:33 AM
JINeration's Avatar
well i tried puttin one of the festoon on in and it sparked thats when it started to dim
Old Aug 17, 2008 | 04:39 AM
if it sparked it prob blew a fuse or the bulb. idn. festoon... thats for the back dome light, correct?
Old Aug 17, 2008 | 04:40 AM
oh and whenever u do work on your car, dis connect the battery!
Old Aug 17, 2008 | 12:17 PM
Yeah, I've had problems putting LED festoons in my trunk light, blew a few fuses that way. Take out the festoon that you put in, then look at the 7.5amp fuse that I think is labeled "dome" fuse in the fuse box in the engine bay and replace it with the spare 7.5 amp fuse. Does that fix it?
Old Aug 17, 2008 | 05:54 PM
SquallLHeart's Avatar
how do you short a dome light and have them still even work??
there's some screwed up wiring somewhere in your car..
Old Aug 18, 2008 | 02:57 AM
JINeration's Avatar
found the problem it was the DOME fuse in the engine compartment it was blown
Old Aug 18, 2008 | 11:47 PM
Make sure you get rid of that festoon that was causing the problem. Took me awhile to figure out which one was causing the problem... by the time I was on my third fuse, the festoon went and left me with a REALLY bad odor in the car. Not good for that to happen, but at least it helped me find the problem. ;)
Old Aug 19, 2008 | 12:20 AM
JINeration's Avatar
yeah thanks for the info guys fixed the problem
horsefeathers
Sep 17, 2023 11:12 PM
Jordly221
Feb 13, 2019 05:29 PM
757_BRDFLY
Jan 9, 2015 12:29 PM
lexobx
Scion xD Drivetrain & Power
Dec 7, 2014 05:52 PM
sithscripter
9
Sep 26, 2003 05:27 AM
