Interior Lighting Mod!!
i have another question about the install:
to wire the Super Bright LED's i would use one resistor for each led....right?
and i found this ot oznium.com
but i don't know how it will work....connect 4 blue led's and then at end add a resistor?
and also which one would be ideal to use 1 resistor for each or 1 resistor for 4 leds??
thanks
LEDs in series without resistors
You can wire LEDs in series without the need for a resistor. For a 12 volt automotive application (which is actually calculated around 14.5 volts):
4 in series (blue, green, white, uv - blacklight, pink, aqua)
6 in series (red, yellow, orange)
thanks
i would have ordered prewired but...i already ordered LED's and resistors
can't wait to install the lights tho!!
by the way....do u have the resistors for the dash light swaps like LEDmod.net have in their kits?? which would go w/ PLCC -2 LEDs for dash light swap..
thanks
thanks
i got my stuff today...but Oznium forgot to put the transformer in for the cathodes
but i called them and they said they will send in..probably getting it on wednesday or thurday...
but i wanted to install my lights today...i'll post pic. when i get em' on!!
jj
jj
You can always do all the work you can today and wire in the transformer when it arrives. =) That's another nice thing about the LED strips, there's no transformer box. Get some nice night shots when you're done!
ok so i went and bought some hood up wires.
So My red 18 gauge wire is "STANDARD", and black (neg) wire is " SOLID"....what is the difference in them...i did'nt open them...so if i need to return em...so should i bother returning em??
I'm not sure of the difference, but I doubt it matters... haha I use speaker wiring for all of my projects
, makes life so much easier because it keeps the positive and negative wires together.
Anyways I'm surprised that you're planning on soldering all the LEDs and resistors yourself considering that you seem relatively new to wiring. Best of luck to you.
I did the prewired, mainly because i don't like soldering, and i don't want to deal with the confusion of resistors. Cathodes for the footwells and leds for the doors and cupholders and such will be fine, it looks perfect on mine, you should have no problems...
^^^ i hope so!!
i am kinda used to soldering and stuff and it is a while now...i have'nt solder anything in like 3-4 years
but i think its not difficult to put leds and resistor together w/ solder
ok so i tried installing the cathodes and i was connecting red wire w/ a white one on the cigar/12v output and guess black is Positive and white is negative (kinda odd)..
but finished installing em;...came out pretty cool..and light output is good blue and matches w/ LEDs!!
but have'nt put the led's in...
clickclickw00t
Feb 18, 2015 08:57 PM
Besk_one
Nov 17, 2003 09:28 PM
sithscripter
9
Sep 26, 2003 05:27 AM
