Led Strips Install Help
Old Mar 27, 2009 | 08:17 PM
SlimJim07's Avatar
Default Led Strips Install Help
I need help installing led strips..can someone tell me how you wire them and what you wired them to?
Old Mar 27, 2009 | 09:57 PM
O5_TRD_tC's Avatar
+ goes to +
- goes to ground
Find a 12v power source
Old Mar 28, 2009 | 12:20 AM
Mr_P's Avatar
Ok you can wire them to that little light in the cubby hole (the little pocket in front of the shifter),
You can get to it by removing the waterfall and then the radio. I did this for a while without any problems. I cut that light off and used the two wires as the positive and the negative.
This will work without problems if you are only using leds and not too many of them maybee a total of 1 or 2 amps of current, I recently rewired because i added more lights and did not feel comfortable using this as the power source. I now use a relay with the cubby hole light wire as a trigger and the power wire run from straight the battery with a fuse of course.
Hope this helps
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
scsteven
Jan 25, 2015 01:06 AM
TheTripleC
Jan 4, 2015 06:46 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
