LED wiring question
So my first mod to the car is going to be some nice LED lights in the interior, but I want to set them up with a switch in a specific way.
Basically I want them to come on with the dome light when a control switch is off, and to remain on without the dome light when the switch is on.
After thinking about this a bit, the project seems much more difficult than I initially thought. Any help?
*Edit* I'm installing footwell and other interior LEDs.
so you want a LED Domelight then or what?
I may be confused on what you want but you can buy those at www.oznium.com
hm im sure u can do that, but im no expert
maybe if you have two switches
one that controls the led's on and off
and maybe another to control the signal coming from the dome lights, to turn that signal on and off?
im pretty confused, but i think if i had to do it, id probably end up doing two switches lol
srry if that doesnt help.
go with a switch like this guy
http://www.oznium.com/gsw-45
and get the on - off - on switch.
you can then wire in the dome supervison wire into one "on" position to send a negative signal to your LED relay, and the other "on" position to ground.
if you want some help with more specific wiring lemme know, but get yourself a rocker switch like this ;)
thanks you helped me out with this, because i was really wondering
bootlgr
Jan 26, 2016 01:22 AM
