lots of electrical problems!
Old Aug 21, 2007 | 03:15 AM
Ishan's Avatar
Default lots of electrical problems!
Ok, so earlier today I installed an SNES into my car, had it hooked up, it worked no problems. then i go out to my car later to go to my friends house..
well, the Brake light and ABS lights are on. The speedo isn't working, the headlights don't turn off when i open the door, the auto window up/down doesn't work, i can't even open the passenger window. wtf!??!
The only thing that went wrong installing the snes is i popped the Cig fuse. Replaced it with a 20 fuse (it was originally 15, my electricion buddy said it wouldn't really matter) but thats it, and now everythings going haywire!
sooo.. any ideas?
Old Aug 21, 2007 | 03:25 AM
jesterscourt's Avatar
when u installed the snes did you disconect the neg terminal on your battery? If so then you need to reprogram your windows.
Old Aug 21, 2007 | 03:26 AM
equinox2355's Avatar
You need to go into more detail about how you installed your SNES into your car to be able to have anyone give you good info besides the windows.
Old Aug 21, 2007 | 03:27 AM
Ishan's Avatar
no i didn't, but I did disconnect it to hopefully clear the brake and abs lights.. how di i reprogram my windows? thats kinda odd...
Old Aug 21, 2007 | 03:32 AM
SquallLHeart's Avatar
you need to reset the windows..
read your owners manual.. and you'll find out that you'll need to first open and hold the close switch for a few seconds for each window at the door it corresponds to
Old Aug 21, 2007 | 03:34 AM
Ishan's Avatar
I've been looking thru the owners manual, I didn't see it in there. no mention of electric windows or anything in the index, i'll find it eventually.
Old Aug 21, 2007 | 03:52 AM
Ishan's Avatar
ok yeah, found it and did it, but my main problem is the 2 brake lights and the speedo not working...
Old Aug 21, 2007 | 04:17 AM
WAlterEgo's Avatar
snes? pull out the fuse and blow on it... j/k
but seriously, you shouldn't replace a fuse w/ a higher amp fuse. it can cause fires! or damaging some more electrical components.
Old Aug 21, 2007 | 04:30 AM
Ishan's Avatar
haha, i like the blow on it thing
I wouldn't usually do that, but as i said.. my licensed electricion friend said it would be fine.
Old Aug 21, 2007 | 04:31 AM
tekstyle's Avatar
agreed with WAIter ego. NEVER uprate a fuse. you should just connect the SNES directly to battery with a voltage regulator. that way, it avoids drawing power through your car's electrical components.
Old Aug 21, 2007 | 04:34 AM
Ishan's Avatar
if i knew how to, i would, I don't really know much about that kinda stuff tho.. but hey the way I did it works, the snes runs, all that. but yeah.. still really just trying to figure out whats wrong with the rest of it and fix it
Old Aug 21, 2007 | 12:01 PM
AKAvensis's Avatar
i think you gotta hit up down up down a b a b..
Old Aug 21, 2007 | 02:01 PM
engifineer's Avatar
Your licensed electrician friend needs to rethink. Where I went to school we were taught to follow wire ratings very closely, and if he is an electrician, as I was before going into electronics and college, an inspector would play patty cake on his **** if he saw him run 15A rated wire (14 gauge) in a house on a 20amp fuse. Fuses are rated based upon the wiring and connectors used to feed them. If it says 15, and you put in a 20, you risk damage or fire if something happens. It was designed that way for a reason. 5 more amps equates to approx 70 watts of extra power. Probably wont burn your car down, but I prefer not to go by probably Wire is not cheap, so if toyota used a 15A fuse, it is because they ran the smallest wire they could to handle 15A.
Old Aug 21, 2007 | 02:03 PM
engifineer's Avatar
Straight to the battery with a fuse would be the correct answer... dont forget the fuse
Old Aug 21, 2007 | 04:55 PM
HR_Guy's Avatar
you get 30 lives that way too
Marvelicious
May 1, 2015 08:00 PM
xxmanrd92xx
11
Feb 4, 2015 01:40 AM
DerekMarq
Jan 27, 2015 02:38 PM
Austin292
Scion tC 1G ICE & Interior
Jan 15, 2015 03:52 AM
Besk_one
70
Dec 31, 2003 05:21 PM
