minor led problem?
Old Jan 15, 2007 | 07:48 PM
GammaTNT's Avatar
Default minor led problem?
i had my gauge led swap done few months ago by someone else.
It was working fine. But recently the "high beam indicator light" won't light up. Could it be the led is bad?
Old Jan 15, 2007 | 08:29 PM
LEDMods_net's Avatar
Strictly Scionized
It's possible. Do your high beams turn on?
Old Jan 15, 2007 | 09:33 PM
GammaTNT's Avatar
yes, high beams do turn on
Old Jan 15, 2007 | 09:37 PM
Strictly Scionized
Yea, it's probably the LED. It's an easy fix. Just ask the guy to swap it for a new one.
Old Jan 30, 2007 | 12:14 AM
GammaTNT's Avatar
i try to solder a new led on it . it still not working, Are there any resister? or a fuse?
Old Jan 30, 2007 | 12:31 AM
falkor's Avatar
Almost HAS to be the LED . Why not contact the person that did the swap directly ? He should take care of you .
Old Jan 30, 2007 | 12:39 AM
fox's Avatar
fox
who did the swap?
Old Jan 30, 2007 | 12:40 AM
GammaTNT's Avatar
he live like 150 mile from me. i am sure he didn't swap the high beam indicator. because it was already Blue from the factory.
Old Jan 30, 2007 | 02:34 AM
falkor's Avatar
Usually , if your cluster is done , even if the indicator is already blue , it will be changed over . But , I have no idea what you had done so , the bottom line is there is most likely a problem with that one light . Good luck
Old Jan 30, 2007 | 03:57 AM
theunclesam's Avatar
I'm surprised no one has mentioned this, but: It could be one of the other LEDs that are actually bad. The LEDs are in a series circuit (like the old x-mas lights) so if one goes, a group of them will go as well.
Have you checked to see if any other LEDs are out?
Old Jan 30, 2007 | 04:44 AM
falkor's Avatar
Good point but , probably not mentioned as most swappers do not do them that way . At least , I know of some that do not . Maybe not most but , I am betting most do it the proper way .
Ferretgrrl
Oct 15, 2018 02:50 AM
randomsuper
20
Jun 13, 2015 10:56 AM
XB06
May 30, 2015 02:42 AM
a_gonzy
Mar 21, 2015 02:40 AM
mischadoll
Mar 9, 2015 05:48 AM
