Is my amp dead?
Okay so I stereo bumping the other day and all of the sudden this weird distorted noise came from the subs and the 40 amp fuse blew. So then I went and got another fuse and put it in and when I turned the radio back on, instantly the fuse blew again.. what could be the problem?
sounds like a bad ground,
where did you ground your amp?
how did you run the wires?
what is the set up?
what gauge wires?
just check your work
make sure all your connections are good.
what is the set up?
what gauge wires?
Well I check all the connections......from the battery and the ground (installed by cartoys) and then the connections to the amps and they are fine.....but it still blew another fuse? Could the hot be niched somewhere from the batter to the amp?
Originally Posted by Fhe1079
Try disconnecting the sub and try another fuse.... if it still blows.. its the amp
Okay, I'll have to go buy some more fuses then. What should I do if the problem is the sub? Can I return it and get another or is that just my fault and I will have to buy a new one?
Blunderbuss
Oct 8, 2015 04:56 PM
Andreas24
Sep 15, 2015 02:10 PM
