OEM bazooka sub on a '10
Probably a quick stupid question, but i already see that the bazooka sub will plug into the stock radio wiring, but is there a way to wire the bazooka to the OEM wiring of the sub next to the spare tire, or does is it direct PnP with the OEM harness?
i know this is a bit old but i'm not too sure, if i would of saw them before i cut the wires off my bazooka box then i could of had checked off my gf's 08 with that lower side sub. but i'm pretty sure you can wire it to the 08 stock sub, just need to find out first what each wire is for and know your grounds, 12 volts, constant power, remote, and the speaker signal. have you tired to wire it yet? also the sub on the bazooka box is an 8" sub, i bought the box thinking i could fit my 10" alpine type-s sub just fine only to find out the sub is a little too big for the box. also tired a 10" kicker cvr and got the same results so i had to modify a panel for the box to fit the alpine sub so it can fit just fine.
Wrencher
Jul 29, 2015 01:38 PM
goatbelly
Jul 12, 2015 10:13 AM
dixonge
Jul 11, 2015 11:02 PM
