Official Interior Dash Thread...
Old Feb 26, 2008 | 07:15 PM
  #481
davedavetC's Avatar
btw you can see it in the 2nd pic too
Old Feb 26, 2008 | 07:20 PM
  #482
tC-N-TC's Avatar
are those the hand controls?
(my friend has a tC and he has hand controls due to the fact hes in a wheel chair)
i think they are neat!
Man, you have a sharp eye fella! Wasn't expecting a reply so soon much less the correct one!
Old Feb 26, 2008 | 07:26 PM
  #483
davedavetC's Avatar
hey what can i say
Old Feb 27, 2008 | 12:25 AM
  #484
yeldak's Avatar
My Girls jank!!!
Old Feb 27, 2008 | 12:37 AM
  #485
tCjayde's Avatar
Aww! Thats sooo cute! I kinda miss mine now... Oh well
Old Feb 28, 2008 | 02:29 AM
  #486
danielleleee's Avatar
Default dash
can u buy the parts to make them the different colors or do u have to paint them yourself? o rpay someone to paint them??? i would prefer to just buy the parts and replace what i have. or what about the keys? I saw someone post a picture of keys with the snap ons ... where do u get all this crap? sorry im new to the scion world, i just got my tc on friday.
Old Feb 28, 2008 | 02:51 AM
  #487
yeldak's Avatar
you can do either... There are a couple people on here that do custom stuff. Delta (I think he changed his name to i-kona) does it I believe and there is another I can't think of....
Old Feb 28, 2008 | 03:29 AM
  #488
astros15's Avatar
whats the best place to buy stock interior dash?
Old Feb 28, 2008 | 04:05 AM
  #489
tC-N-TC's Avatar
I'm unsure about where to purchase it new but a cheap alternative is to use http://car-part.com/ and find what you're looking for locally or nationally if you dont mind waiting and paying for the shipping? I paid $65 for a replacement Hvac w/the bezel included whereas the dealership wants somewhere around $400-$500 for the Hvac alone!
Old Feb 28, 2008 | 06:12 AM
  #490
yellowxhoodie's Avatar
Default Re: dash
well if your new to scions, i have one word.
legos!
lol, a little joke me and my buddys have when were working on the tc and their civics.
we call them lego cars cuz they are so easily disassembled and everything snaps on/off so we just randomly yell out LEGOS!
Old Feb 28, 2008 | 06:14 AM
  #491
tCtCtC's Avatar
watching....
might do mine.
Old Mar 2, 2008 | 04:28 PM
  #492
07tctul's Avatar
this may have be answered already, but can i just use duplicolor bsp spray paint.
Old Mar 2, 2008 | 10:13 PM
  #493
yeldak's Avatar
the black from the pink/black above, and the clear are both duplicolor
Old Mar 4, 2008 | 01:59 AM
  #494
exzess's Avatar
hey u guys I want to paint sum parts of my dash and saw the link on how to take em off, but does any specialist here wanna show how to paint it (like wat kind of paint, how much drying time, how to make it look glossy). please?
Old Mar 4, 2008 | 02:58 AM
  #495
yeldak's Avatar
Heres how I do it
First things first, make sure first to get all the armor all or any type of dressing type protectant off of the pieces you will be working with. I usually do it with some simple green, and then isopropyl alcohol.
Prep
Smooth Pieces
Wet Sand all smooth pieces (waterfall/radio door/etc) with 1000 Grit sandpaper (try to remove all the factory color, if you get it all off, you can get away without priming these pieces). If you do have to prime, or just want to prime, I usually start with 2-3 coats of duplicolor adhesion promoter
. After adhesion promoter is tacky, I would say 2-3 coats of a regular duplicolor primer. with 10-20 minutes between (it all depends on temp, humidity etc). You want the paint to be tacky between coats.
Textured Pieces
Dry sand all textured pieces (cluster surround/vent surrounds/etc) with 400 grit sandpaper. These pieces will have to be primed. I usually start with 2-3 coats of duplicolor adhesion promoter
. After adhesion promoter is tacky, First I usually use Duplicolor filler primer
. I do 2-3 coats with about 10-20 minutes in between (it all depends on temp, humidity etc). You want the paint to be tacky between coats.
Let that dry overnight
After fully dried, get a bucket/sink etc with a good soapy water solution, you want to be able to feel the soapiness of the water. Using 1000 grit sandpaper I sand until smooth, being careful around edges and corners, if you sand through, repeat steps above by doing the spot that was sanded through. Keep your sandpaper clean, rinse it around in the water every so often to get rid of any dirt or whatnot. the best way to tell when its done... on day 1, if you are using a light colored primer, take some dark colored spray paint, and spray a light guide coat onto the panel. This will give you a guide when you start sanding on when to stop, when all the guide coat is gone, your panel should be smooth.
Thoroughly rinse everything you just sanded, you want all that sanding residue off. Set them on a towel or whatnot to dry completely. Make sure everything is dry before moving on. This includes the foam that is on some of the pieces.
Now should be ready to paint. For the most part, I use duplicolor , normally the lacquer version, for certain colors, you have to move to krylon/rustoleum/etc. If you have a certain pattern, such as the 2 tone above, I usually spray the lighter color first. Position the piece you are going to paint in a way it will be easy for you to get the whole panel. I sometimes have to string things from the ceiling to be able to get into all the little spaces. I start by spraying 2 coats of Adhesion Promoter mentioned above. When spraying, you want to hold the can 8-10 inches from the panel, make an even stroke across the panel while spraying, you want about a 50% overlap on passes to get good coverage. I normally spray 3-5 coats of color, it all depends on the color/conditions and how good the coverage is. Keep your coats light, you can always add more coats, its not as easy to get a run from too thick a coat out. About 10-20 minutes between. Again, it all depends on your painting enviroment. Just check to make sure the paint is tacked up (sticky) between coats. If you happen to be doing a 2 tone, or just multiple colors, you want to let your first color sit for about 2-3 hours before laying down tape. I always use the blue painters tape, it peels off pretty clean, and if for some reason your first color wasn't so dry, it won't tear the paint up so bad you'll have to wetsand, I've cleared right over the tape marks and you would never know it. Anyway, when you are satisfied with your taping, repeat above for your second color.
Once color is on I let it dry for about an hour or 2. If for some reason I got a little too thick with the color, I'll wetsand out any imperfections and recoat. Some people sand between color and clear, I'm not a fan, and this is my write up!.... So, as stated above, get your pieces into a position where you can get good coverage. Spraying clear is a little tricky. I would suggest getting some practice on what works for you. I normally to 3-5 light coats, 1 medium coat, and 1 medium-heavy coat of clear. I know thats alot of clear, but alot of it comes off in the wetsanding phase. As stated above you want about a 50% overlap to get good coverage. leaving about 10-20 minutes between coats depending on conditions. Once you spray your final coat... make sure you have your pieces somewhere they won't be disturbed. Try to keep them out of a spot with alot of dust blowing around as well. I will let the clear sit overnight, sometimes 2 days, depending on how dry it is. When it is dry, you are ready for wetsanding to smooth that bad boy out.
Remember in the sanding step above that soapy water solution... do that again, this time you will be using 2000 grit sandpaper though. Make sure to keep your sandpaper rinsed out, keep the panel wet, and don't let any dirt sit on the panel... trust me, you will notice the scratches a spec of dirt will leave. Be careful around edges and corners, as you will sand through before you know it. Once the panel is smooth enough to your liking, Rinse clean of all the sanding residue and I usually use a microfiber towel to dry. I do 3 buffings, all by hand..... and then a wax.
For the first buffing, I use a microfiber towel along with turtle wax rubbing compound getting the rag damp, dip into the compound and rubb away. I usually use a 1 finger circular motion. Use a clean rag to wipe off. This will bring out a shine, but it will be a dull shine... settle down, it gets better I promise.
2nd buffing is done using a DRY microfiber towel and mequirs deep crystal polish using the one finger circular as mentioned above. Again using a clean towel to remove.
3rd buffing is using the same product above (meguiars deep crystal polish), on this time you'll use a wet microfiber cloth, one finger circular motion bringing out the shine. again using a clean towel to remove. If its not shiny to your liking, repeat the above steps until you get your desired result.
And for the final, I throw a coat of my favorite wax (which happens to be meguiars deep crystal wax) before reinstalling in the car. In between waxings I just use a simple quick detailer, the same stuff I use on the outside to keep up the shine....
Hope this helps anyone who wishes to DIY
Old Mar 4, 2008 | 04:14 AM
  #496
deflaytedwayz1's Avatar
Wow that must have taken forever to write. Very good write up. I'll be doing mine in about a month once my new garage "paint booth" is all cleaned out but i'll be using regular automotive paint.
Old Mar 4, 2008 | 03:59 PM
  #497
exzess's Avatar
wo0w thanx!!!!!! but man must've taken a while...if u give me ur mail adress I'll ship u my CD for free [: click on my pic to listen.
Old Mar 6, 2008 | 03:42 PM
  #498
exzess's Avatar
Originally Posted by phoenixtc
Here is mine.
Ok Im lookin for a place to do this so if anyone is in the MD area I'll give u 100 bucks. i dont trust myself too much lol. im free on sundays and wednesdays if i have to drive sumwere. who would do it? its only paint to 2 blue parts in the center and 2 parts in the doors. let me kno what u think.
Old Mar 6, 2008 | 06:06 PM
  #499
x_Batman_x's Avatar
Here is mine.
I'd be happy do it for you if you want to drive over to Michigan
Old Mar 6, 2008 | 07:43 PM
  #500
tCjayde's Avatar
Its so easy to do! I dont know why youre scared to do it =)
