PLEASE explain D3 mounting bracket(kinda urgent)
ok I have installed my D3 wih great pride.
only thing is of course the door doesnt close.
can someone explain the "drill 3/16"" part??
Im good with tools I just dont understand that for some reason.
Do I drill "back" 3/16 or do I make the hole larger???
someone please explain,im going on a road trip and staying in a hotel and dont want any problems
anyone got any pics of a before and after or something,I dont know why but it has me confused......maybe cuz its 2:30am??
https://www.scionlife.com/forums/viewtopic.php?t=165675
6th picture down... shows u how it should look after I drilled mine with 3/16' drill bit
drill where their are small indents and use those to mount the d3 instead of original holes so the door closes flush
if you are talking about the one with the harness, it looks like there isnt a hole for it (the third one), or its covered by the metal. and if its just the harnes youd only need 2 on each side (its mainly food looks doing this kinda set up, since the metal harness is your main one. there looks to be still three screws that actually hold the deck in the metal bracket. at least from the looks of it.
lol, i think you have to try to mess up. its not that hard, you see where the **** hits, and dremel away. as far as being easier and cleaner? i did it my way cuz at first i tried to drill, but i didn't have a bit for drilling into metal. so the dremel was easier in that sense. as far as clean, you can't see it at all, it is behind the door after all.
but ya, i guess if you don't have a dremel, then my way is hard. just throwing out another option out there.
Having the headunit recessed by drilling in the brackets is probably the easiest method.. and since it recesses the radio in the dash a little further, it keeps the sun from glaring on it as much as before ;)
Jay
Jay
hey i drilled where that picture (6th down) shows. IT WORKED GREAT! course i have the kenwood ddx-7019, but the door closes with the radio off and with the screen in the inverted angle and the first angle-out (u know when the screen has the bottom part angled out...) if u adjust the scrren angle any more, the door wont close i think. of course with our sunroof the inverted angle works best anyways. thanks again for the great diy help.
Exokutioner
10
Jan 26, 2009 08:37 PM
TheDave1022
Scion tC 1G ICE & Interior
177
Sep 28, 2008 06:31 AM
riccochetrabbit
15
Jul 21, 2005 01:49 AM
