Please Help, Component install.
Old Feb 5, 2008 | 04:53 PM
Keeshwah's Avatar
Originally Posted by XSNiper
What are the chances this is a bad amp? I bought this thing from ebay and it was New in box. When I put the RCAs in the preamp section on the amp the power light comes on, when I move it to the amp input section the power light doesn't come on. When I jump a wire from the +12v to the REM section I measure 3V at the +12v section. What is going on here? I don't want to eat $260 and pay another $140 to figure out it was a bad amp and another $150 to buy a new amp...
do the simplest test. take some speakers and plug it directly into the amp (or a DMM if u have one). also remember ur car chassis is all grounded to the negative terminal of ur battery. speaker wires touching that chassis would be bad and u should of heard something that didn't sound good when that happened.
Old Feb 5, 2008 | 08:36 PM
XSNiper's Avatar
New Development.
I did something I should have done before I wasted all my supplies. I used the power/ground/rem/rca's from my sub/amp and connected them to the new amp. Well, this powered the amp right up fine. However, I'm not getting sound, or very loud sound, from my speakers. They are playing but you have to really crank it up to get even audible sound...What could be the issue? And yes I moved the rca's to the front section on the head unit.
Old Feb 6, 2008 | 12:36 AM
nodsetse's Avatar
Originally Posted by kidwolf908
...it is in fact a remote turn on wire, 100% sure. ...the amount of power passed through the turn-on lead is SO low that you'll NEVER notice it.
Totally agree on those points, many companies have been making RCA cables with an integral REM lead for years, and people haven't had noise issues when the REM trigger is connected to an appropriate source.
Originally Posted by nebster
meh, if you have sheilded rca cable you're fine.
There's no need for shielded RCAs in the tC either. All that's needed is a twisted-pair design, as that inherently rejects the type of radiated noise in question.
In fact, we actually all have incentive to AVOID shielded RCA cables. Why? Because the shield itself is a conductor. If the shield has a gap anywhere, allowing noise to be introduced at any point in the shield (cable is running along the car body, body has a lot of current flowing through it all the time, as the body is the car's ground point for EVERYTHING), then the shield will transmit the noise the entire length of the cable, resulting in a greater potential to introduce audible noise. That can't happen with non-shielded cable, and since a twisted-pair design does such a great job at rejecting noise, I suggest avoiding shielded RCAs.
Not arguing, just presented for what it's worth, do whatever makes you happy.
Old Feb 6, 2008 | 04:34 AM
z-lite's Avatar
Take a speaker and get a foot of wire and wire it directly to the speaker terminal of the amp. Plug the RCAs into the amp input, put your volume around 50% on the HU and play music. It should turn on and play music. If the volume is low, you can adjust the sensitivity/gain on the amp to increase the output. Does it do this?
Old Feb 6, 2008 | 04:37 AM
Snakeslife's Avatar
run extra remote cable from your deck to the amp and the cable that on your rca ground it if you can
Old Feb 6, 2008 | 01:43 PM
XSNiper's Avatar
I wired up one of my computer speakers directly to the amp and I'm getting audible sound.
Old Feb 7, 2008 | 04:31 PM
XSNiper's Avatar
Ok, I took it down and got it wired up and everything. Now I have another problem. When I turn on the stereo and keep the volume low so I can here other things I get a horrible nnnnnnnnnnnnn sound coming from the speakers. It starts when I turn the key to On or with the engine running. It stops when I turn the key to ACC. Anybody know what kind of noise this is? I have a Pioneer deck. It doesn't increase with volume and it doesn't change pitch with acceleration.
Old Feb 7, 2008 | 04:32 PM
Keeshwah's Avatar
plug it in somewhere else to make sure its not busted.
Old Feb 7, 2008 | 04:43 PM
XSNiper's Avatar
The noise wasn't there before. When I unplug the new rca's the noise goes away, with my sub/amp rca's still connected. When I plug the new ones back in, I get the noise.
Plug what in somewhere else? The rca's or the deck?
Old Feb 7, 2008 | 04:46 PM
z-lite's Avatar
Take it to a shop and have them fix the problems. A shop is more qualified to troubleshoot a problem because they have physical access to your car and we don't. Don't gamble with your equipment if you're not 100% on what to do.
Old Feb 7, 2008 | 04:48 PM
z-lite's Avatar
There's your problem. Pioneers are notorious for having a faint noise in the RCAs if you plug/unplug them while the radio is on.
See if this link will help http://icixsound.com/vb/showthread.php?t=40067
Old Feb 7, 2008 | 04:49 PM
Keeshwah's Avatar
its possible ur having the pioneer ground issue... you could try this:
http://www.caraudio.com/forum/showth...neer+grounding
Old Feb 7, 2008 | 05:59 PM
XSNiper's Avatar
I can't believe it worked....Theres still noise but you REALLY have to try to hear it. Thanks guys.
Old Feb 7, 2008 | 06:19 PM
z-lite's Avatar
What did you do?
Old Feb 8, 2008 | 02:46 AM
XSNiper's Avatar
I did this
http://i72.photobucket.com/albums/i1...l/IMG_1066.jpg
but I didn't ground it the same way they did. What I did was took the other ends of the wire and put them under two screws on the metal casing of the deck. Simple, but extremely effective. I did this only to the new ones and the noise is gone.
mischman
Sep 15, 2015 03:38 PM
sciongirl13
Scion xA Aero & Exterior
Jul 22, 2015 02:28 AM
hampton1100
May 28, 2015 07:32 AM
corbmonster
Jan 24, 2015 06:13 PM
cwong1001
Dec 3, 2014 03:30 AM
