Power getting sapped
Once again, the OEM battery and alternator are just fine for most systems. It's only when your system is drawing hundreds of amps (very unlikely - but say at an SPL competition, during a 'burp'), that additional batteries would help. The other reason to get multiple batteries would be for extended engine off listening time at 'regular' listening levels. It's all about the charge/discharge rate, and nothing beats the bank of small caps inside each amplifier. Next would be an external capacitor, mounted very close to the amplifier's power input terminals. The deep cycle batteries have the slowest charging and discharging rates; even worse than the OEM battery. For this reason, they're more of a burden on the electrical system. If the system is designed for SPL competition - multiple quick discharge batteries are about the only option because of the amount of current needed over 30 seconds. The goal should be to increase the wire gauge to lower resistance (raising voltage) to each amplifier. I've yet to see a daily driver that "needs" any additional batteries for the sole purpose of curing the dimming lights issue.
i'm running just shy of 800watts rms from an mtx mono block class D and i get no dimming at all, my deck has voltage readout and i have never seen my voltage drop more than .3 even on the most demanding music. the only time i saw dimming in the tc was when i ran a rockford fosgate 801s at 2 ohms bridged for a night(they aren't meant to be bridged at 2 ohms, and they get extremely hot extremely quick doing it). but with that little power i'm shocked to hear of dimming.
im doing my big 3 once i get my car back. already got wire
Originally Posted by rvpps2rocks
lol i must be doing something wrong becuase im running a 600 watt amp but tuned down to 500 watts for a 500 watts rms sub and im running only my optima and my lights get reduced to about 2/3 of the full lighting capacity so it looks i lose a 1/3 of my output when the sub hits hard its a single 12" in a sealed box
If you're going to say "with the gain ****", I can tell you that your amplifier will still reach full output potential, but will require a larger line input voltage (RCAs). Conversely, with the gain **** cranked all the way up, a smaller input signal will make the amplifier reach full output power - and too large of a signal will clip the preamp, or overdrive the amplifier. There is no "power choke" method to de-tune the amplifier, other than limiting the power input voltage (inadequate cable size, low supply voltage, etc.).
Gain ***** are a level matching device, intended to compensate for different efficiency speakers and/or size amplifiers.
Originally Posted by rocketgyrl
Originally Posted by Jan06xB
You should really do a high cranking amps battery right at the power connections to the AMP like a Red Top Optima - they respond faster to current demands and hold up the voltage better then a stiffener cap which is also a good idea but you need a really big stiffener cap for bass filtering. Putting a really good battery right at the amp solves the cabling issue since you don't have to worry about voltage drops in the cables to the main battery and alternator or the chassis grounds for that matter either. And forget about the heavy duty chassis connections - the steel chassis has more resisstance than the copper cable you are using - just run the copper cable to the amps positive AND negative connections from the battery Positive and Negative clamps and maybe run an extra ground from the battery to the alternator frame bolt.
Let's take your beloved Optima Red Top (starter) battery for example. I looked at their website, and found a nice round number of 1000CA on their largest model. Cranking amps (CA) is the amount of current a battery can provide at 32 °F or greater. The rating is defined as the number of amperes a battery (at that temperature) can deliver for 30 seconds and maintain at least 1.2 volts per cell (7.2 volts for a 12 volt battery). Peukert's Law expresses the fact that the capacity available from a battery varies according to how rapidly it is discharged. A battery discharged at high rate will give fewer ampere-hours than one discharged more slowly.
That being said, I submit that NO street stereo system will draw anywhere near 1000amps - especially for 30 seconds because music is dynamic. Add the fact that the alternator is constantly charging the battery. I realize there are additional loads on the charging system, but still - plenty of power is available for street systems. The Scion alternator in the tC is 100amps.
You stated: A farad is the amount of capacitance that requires one second for a one ampere flow of charge to change the voltage by one volt - which is correct. As I've mentioned before, the ESR of any capacitor is MUCH lower than a battery, and will therefore charge and discharge faster - maintaining a smooth voltage. Once again, I've yet to find an amplifier that can not sustain regular music play (re: not 'burps') when proper wire gauge is used, making the addition of an external capacitor unnecessary.
The car's alternator ampere rating plays the major role in determining how powerful an amplifier(s) you can install. Multiply the alternator's ampere rating by 40%, and you'll get a rough idea of how much reserve current capacity your car's system has.
To calculate the current draw of an amplifier, multiply the number of channels by the RMS watts per channel (a 4 channel amp rated at 100 watts RMS per channel would be 400 watts). Double it to account for amplifier inefficiency (400 watts X 2 = 800 watts), then divide by the average output Voltage of an alternator, 13.8 volts (800 divided by 13.8 = 58 amps). Since the average music signal requires about 1/3rd of the average power in a test tone, divide by 3 (58 amps divided by 3 = 19 amps). The result is the amplifier's approximate average current draw. In short, a 400 watt class A/B amplifier draws about 19 amps when playing music! Most people use a class D amplifier for their subwoofers, which are somewhere around 90% efficient, not the 50% figure I used for the class A/B amplifiers in the example above. So a 1000 watt class D subwoofer amplifier draws about 1100 watts at full power (rarely, if ever happens), and would draw somewhere around 27 amps while playing music. That's about 46 amps (19+27) of current draw while playing music - pretty loud. Again, since music is DYNAMIC, these numbers aren't constant, and will be lower most of the time, giving the alternator a chance to charge the battery!
A fast-and-nasty way to ballpark an amplifier's current draw is to divide the total fuse value of the amp by two. For amplifiers with multiple fuses, the rating of all fuses provided with the amp must be added together. This will likely produce a significantly higher estimate than using the proper formula. Although inaccurate, this will err on the side of safety.
School's out.
Very impressive but is a Lead Acid battery with some miles on it going to have the low output resistance needed to handle the bass surges and is the cost of 4 AWG or thicker wire going to cost less than a Red Top and it STILL only connects you to a used possibly tired car battery when all you need to do is put a good RedTop on the amp to handle it all with reasonable wire feeding it the average current you calculated that the alternator can provide. The fact that the lights are going dim indicates an aging car battery or some in line resistance in the power connection to the battery dropping the system voltage enough to be noticed.
Why are you pushing Reds soo hard? If you scratch the surface, you'll find out that very few car audio competitors use Optimas. Why? Because they fail without warning. I've personally gone through 3 Optima batteries in 2 years (previous car). I've mentioned a few other great "stereo" batteries in previous threads, to include:
http://scosche.com/efx.aspx?CategoryID=51
http://www.svrbatteries.com/
http://www.kinetikaudio.com/
http://www.batcap.net/
However, I'll let you in on a little secret...I've competed for 2 seasons with a 1600 watt system, put my car though 2 brutal Colorado winters, and won't give up my OEM battery for any after-market unit.
Lead-acid batteries generally fail when one of the 6 internal cells fail (open). I'm unaware if any internal resistance that builds up - but I'll wager that it's a very minor increase over it's usable life, then a catastrophic failure. It's hard to say if your holier than thou Optima's are plagued with this same problem. I can only assume this is a non-issue. The battery either works, or it doesn't...
You're still missing my point though...I've shown in my previous thread that the internal capacitors in the amplifiers and OEM alternator are enough to support a ~1400 watt system - when cranked...never mind the battery! At this point, the battery is just another filtering device!
The dimming issue is more likely due to the contacts corroding - either at the battery, alternator, ground, etc. This is why I strongly suggest doing the "big 3 upgrade", and using proper wire gauge for ALL stereo components.
I've exhausted my vocabulary from explaining this issue countless ways. If you still feel a Redtop is the holy grail of car audio power solutions, by all means, go waste your money.
Nope I never had a Red Top, I have 11 of the Hawker Genises 26ah batteries that I use in my electric vehicles and I have hear of the Reds failing usually from the tightly wrapped plates shorting out. You also should know that the motors I am running are over 90% efficient due to very low internal resistance - in fact if you short out the windings and put a vise grips on the shaft and try to turn it the wires will heat up and it will be very hard to turn the motor - winding resistance is in the milliohms. Yes the standard old car batteries do develop higher internal resistance as they age usually they loose capacity too but not to many people deep cycle them to find out just how quickly they deteriorate. I usually get 10 or more years out of my car batteries without any problems simply by NOT jumping someone elses dead battery with my car or leaving my lights on and running the battery down. Personally I think massive amps in a car are a little crazy and the energy is better spent making the car go - but then again my hearing is very good and I don't need a lot of power to hear music.
You sound like you have an EE degree or spend a lot of time installing amps in cars?
Originally Posted by Tcguy85
rocketgyrl..... will you marry me? there needs to be more girls out there that are into cars and car stereos like you are!
Nope I never had a Red Top...and I have hear of the Reds failing usually from the tightly wrapped plates shorting out...
...Yes the standard old car batteries do develop higher internal resistance as they age usually they loose capacity too but not to many people deep cycle them to find out just how quickly they deteriorate. I usually get 10 or more years out of my car batteries without any problems simply by NOT jumping someone elses dead battery with my car or leaving my lights on and running the battery down. Personally I think massive amps in a car are a little crazy and the energy is better spent making the car go - but then again my hearing is very good and I don't need a lot of power to hear music.
Actually, it's all soaked in from hanging around Matt for 5 years. He's the one with a Masters of Electrical Engineering, specializing in Digital Signal Processing and two Bachelors: EE, and ME. He's been installing systems for 15 years. By day he's an F-16 pilot - by night he's an installer, doing competition level systems. He's opened his own high end shop, Mobile Audio Werks, 4 years ago. The two of us compete with both IASCA and USACi - sound quality. Currently, I'm the World Champion for USACi, and have a bigger trophy than Matt
can i come work for this matt?
http://autosound2000.com/as2k/autoso...fs_thebook.htm
"A2KTB" was written by the "Founding Fathers" of car audio. They've taken a no-nonsense approach to the discovery of car audio. It was written during the late 80's, and early '90s when car audio was in it's prime. It does an excellent job breaking down and explaining all facets of car audio.
Go to as many competitions, IASCA/USACi/MECA - even as a spectator - as you can. These shows have collective best-of-the-best car stereos, installers, etc. Talk to those that are as passionate about car audio as you! Ask them questions about system design, speaker location, tuning, installation, sound damping, etc.
Here's USACi's event calendar:
http://www.soundoff.org/cgi-bin/sche...&display_all=1
IASCAs:
http://www.iasca.com/events/
MECAs:
http://www.mecacaraudio.com/eventtable.aspx
I think it's the Red Top ads along the right side of the screen in SL that has been pushing me in that direction. Yellow Tops are more popular for deep cycle use in the EV area - don't have any of those either because the spec on the Genesis batteries are a little better for cyclic use, got a great deal on ebay 5 years ago on them and I love the way they can take a 60 amp charge and be almost full in 45 minutes with just a little heating. Sorry if I questioned your credentials but I had not seen all your other threads.
So to ask a really technical question - do these high powered amps run 12 volts internally or do they boost the voltage with an inverter to get the higher output voltage needed to drive the speakers? Seems you need about 40 volts into a 4 ohm load to peak the power at 400 watts and more if we are talking RMS.
Yeah now we start talking about bridge outputs and floating potentials or single ended outputs with capacitor coupled outputs and power up charge surpressor circuits. It does explain the amps ability to handle peak power levels without overloading the battery for a second or two. Bet you are waiting for ISA to become popular so you can start running everything at 42 volts input voltage!
Yeah - the microscopic level of this stuff can be interesting - like to crimp or solder the ends of heavy conductors carrying high currents. Military wiring calls for air tight crimps with very expensive and specialized tools but I always solder and flow some up the insulation so that all my joints stay cool and conductive even when passing 150 amps for a while. I even use an IR heat probe to check for temperature rise.
ummm jan i think ur thread jacking now...hhaha and rocketgyrl i tuned my amp to 500 watts but right now from what ur saying i didnt because i used a test tone cd...anyways im saving for my mag d2 i wanna get
How exactly did you tune it to 500 watts? Did you measure the AC output at the speaker terminals, with the speaker playing?
I'm suggesting that IF your amplifier is capable of sustained 600 watts (or even 500- most aren't), that it WILL still reach that amount - but will require a larger input voltage on the RCAs. IF your headunit is the limiting factor ie: it can't produce the required voltage on the RCAs to drive the amplifier to 600 watts, OR if you adjusted the gain **** to disallow the amplifier it's full potential when your headunit is cranked, then your statements would be correct.
