Power Windows not working.
Power Windows not working after Engine replaced. Sunroof is the only thing that works after the engine was replaced.
I have checked the fuses and they are both fine. I haven't pulled the relay to check if that is it. but the Power Locks button works but the Power Windows Switch doesn't, work at all. What else should I do because I don't want to put a trash bag on my window every time I go to work? Please message me or leave a comment if you have had similar problem. Yes I have tried the reset method after the battery was removed,
Do both the driver and passenger window switches not work or only the driver side? Are the lights on the switches blinking?
What you probably need to do is pull the door panels off, find the wire/plug that goes to the window motor and see if you're getting power there, also test when you press the switch as well.
imagin
Scion tC 1G ICE & Interior
11
Oct 22, 2021 02:28 PM
wurkinonatc
Apr 4, 2011 05:22 AM
