problem with my cap...
so I uninstalled my stereo a while ago. I decided to put it back in tonight. Rerouted everything tonight just like it was before. Hooked up the amp and ran it to the sub. I have a one farad cap I use, simply because the lights flicker otherwise.
I ran the battery power into the cap. I ran a negative from cap to chassis(solid seat belt bolt connection that I used previously). I then ran a power from cap to amp, as well as negative from cap to amp.
Cap doesn't turn on. I then lock and unlock the doors and the cap lights up flashing 0's eventually turning off. I tried running the resistor light to positive negative until the light turned out, but it simply drained the cap as opposed to charging it.
So right now, the amp powers on, but the cap does not.
Why does this happen, and what can I do to fix the problem. I've installed about 6 of these things and have never had this problem before. The cap WAS drained after I took the system out a few months ago.
I fried a resistor.. problem has been resolved.
Ok, but I'd still like to know what kind of cap you have. That might help me understand what the issue was, such that I could resolve it if I ever encounter it with that type of cap. Your explanation of the solution has me baffled too, as once I charge a cap there aren't any resistors to worry about, but your cap must be different. Got a link, or would you just state the brand/model? Thx!
RY_TC07
Jul 18, 2017 05:18 PM
