Quick Fiberglass Question
Originally Posted by BlueTC06
Use the thicker matting it will save u time and money...plus it stronger
I used chop mat. It is stronger because the strands go all different directions and interlock instead of the cloth where the weave only goes two directions. It does look prettier though and I am guessing is easier to use. The chop mat clumped up when I painted on the resin. Not fun.
The cloth is technically stronger but from experience the mat is extremely easier to use, since you can rip it and it will thicken up much faster than the cloth. You will need more of the cloth to get the same thickness as the mat also. I have used mat in most of my work and only dealt with cloth once, it is a much better choice. good luck and if you are looking for ideas check out my box FS in the classifieds, it can give you a few good ideas if you are still looking
The mat is strong its got pieces going every which way. It makes it much stronger.
As for the mat a 1.5 oz is a good medium to use... easy to work and still not super thin.
Get a paint brush and chop off like a inch of the brush.... makes it more stiffer and gets the bubbles out.
bootlgr
Jan 26, 2016 01:22 AM
ShadowMage
16
Jul 25, 2004 06:02 PM
