Quick Question on D2 headunit install..
Old Dec 30, 2006 | 10:50 PM
fearthisinc's Avatar
Default Quick Question on D2 headunit install..
i installed the Avic-D2 headunit in my girlfriend's tc but she thinks it sits to far back.. i used the stcck mounting brackets and drilled out all the indents as posted in another thread.. the only way it fit was to use the 2 holes that i drilled toward the front of the unit.. she thinks it sits too far back and that it is slanted up to high.. ill take some pictures in a few but figured id ask and see if this was a common problem or easy solution..
Old Dec 30, 2006 | 10:53 PM
SquallLHeart's Avatar
i'd say just drill different holes..
Old Dec 30, 2006 | 11:15 PM
here are the pictures of what it looks like.. i took as many as i could with angles that might help to see.. i think it looks fine but i do see where she is coming from... it does slant a little upward and whatnot.. well ill let you guys look and you tell me what you think needs to be done... thanks for any input..
Old Dec 31, 2006 | 09:15 AM
REaL's Avatar
yea that does look a little strange, it shouldn't be slanted. Try removing that trim around the head unit. Your actually not suppose to use that trim because theres a kit for the sides you can buy from scosche to fill the gaps. Heres mine hope the big pic helps you.
turnonthebrights
Sep 17, 2007 05:16 AM
optimus10
Scion tC 1G ICE & Interior
Aug 20, 2007 05:46 AM
zdawg913
14
Mar 24, 2007 08:32 PM
USFxA
9
Oct 16, 2006 12:31 PM
Typhoon
Dec 25, 2005 07:11 AM
