Quick Wiring Question
Old Feb 1, 2010 | 12:05 AM
scionTC188's Avatar
Default Quick Wiring Question
Alright I have never wired anything in my life, by reading through these forums I have managed to hook up a couple LED's into my car. I put the lights in today, everything works lights up, looks great. I bought the single LED's, not a strip or a bar. When I wired them up a took a long power wire, then stripped each led one by one. So the final connection looks like a T for each LED. To secure the connection, I twisted the wires together then wrapped it up in electrical tape. My question is that did I secure the wires well? Is electrical tape a way to do it? Is the way I secured it safe? Yes the lights work, yes I did put in a fuse.
Old Feb 1, 2010 | 12:21 AM
SquallLHeart's Avatar
electrical tape isn't the best thing to use.
taps would be the easiest things to use.. and though just wrapping wires together works.. a more secure connection would have the wires soldered together.
instead of electrical tape, i would use heat shrink tubing.
Old Feb 1, 2010 | 12:28 AM
scionTC188's Avatar
ok, but for the meantime it'll be fine just with the tape?
You dont think it'll burn through or anything because of the heat?
Old Feb 1, 2010 | 12:38 AM
wired correctly.. there shouldn't be heat.
Old Feb 1, 2010 | 12:40 AM
scionTC188's Avatar
alright thanks
Old Feb 1, 2010 | 12:53 AM
myTwhyT's Avatar
solder and shrink tube are always great! very secure and looks cleaner!
Old Feb 1, 2010 | 01:57 AM
KaneoheKoa's Avatar
While soldering is the best connection, most of the times it's done wrong (cold solder joints, melted through insulation}. Also, when dealing a twin lead situation like an LED, you'll need to stagger the solder points to maintain a smoother profile, and use 3 pieces of heat shrink. Narrow body crimps are preferred in this case. For LEDs, use inline 20ga crimps and a quality crimping tool (I like the Klein cutter/crimpers). Crimping is easy to learn and master and avoids things like: burnt fingers, carpets, consoles, components and harsh language when you do the previous mistakes.
Old Feb 1, 2010 | 06:24 AM
chitown's Avatar
x2
there are also butt connectors that you can use, but professionals prefer soldering wire together.
Old Feb 1, 2010 | 02:28 PM
cobaltbravo's Avatar
+1 solder and shrink tube
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
ShadowMage
16
Jul 25, 2004 06:02 PM
vpkb
12
Oct 8, 2003 04:17 AM
