radio trouble please help!!!
Old Feb 4, 2006 | 12:25 AM
jamrok55's Avatar
Default radio trouble please help!!!
just installed an amp kit with the original radio the rem wire hit the groung by mistake it sparked and my radio shut off i checked the fuse under the hood its good now what?
Old Feb 4, 2006 | 12:54 AM
jallamas's Avatar
Is there a fuse on the back of the Head Unit?
John
Old Feb 4, 2006 | 12:57 AM
jamrok55's Avatar
nope i checked
Old Feb 4, 2006 | 01:56 AM
jallamas's Avatar
You said you check the fuse under the hood meaning the amp fuse? also check the fuse box fuses.
John
Old Feb 4, 2006 | 02:19 AM
jamrok55's Avatar
i did
Old Feb 4, 2006 | 02:34 AM
tat2dude25's Avatar
Check the fuse in the fuse panel and under the hood. If no there may be a fuse inside the head unit itself. May have to take it apart to find out. Im looking at mine and I almost bet there is one inside. Personally I would junk it at go get an aftermarket H/U, as they are 50X better. Another option put everything back to original and make a warranty call to the dealer.
Old Feb 4, 2006 | 09:40 PM
jamrok55's Avatar
just did that dealerships suck what a hard time they gave me because i left the amp wires in the car thank got it was a fuse under the dash
Old Feb 4, 2006 | 11:56 PM
jallamas's Avatar
Cool, glad its fixed!
Old Feb 5, 2006 | 01:26 AM
tat2dude25's Avatar
Nice, they couldv'' used that as a way to say "Warranty VOID"!!! Glad it all worked out.
Old Feb 5, 2006 | 10:16 PM
lovemysciontc's Avatar
yes glas it all worked out for you, had the same problem myself, thanks
Old Jul 6, 2006 | 05:21 AM
davetex's Avatar
do you remember where the fuse under the dash was located? i have the same problem and i need it fixed asap! thanks.
Old Jul 7, 2006 | 01:38 AM
tat2dude25's Avatar
I am not sure of that fuse but your owners manual will tell you where they are and what they do. Check that.
Old Jul 7, 2006 | 03:14 AM
davetex's Avatar
Default found it. radio is fixed.
in addition to the fuse box under the hood, there is another one located way up under the steering wheel. you dont have to take the dash off or anything to get to it, but it was back there a little bit. i had to do some in-car pilates just to fit there.
prescottn
Oct 8, 2015 05:31 PM
DannyBoy65
Sep 21, 2015 06:23 PM
dyenfd
Sep 13, 2015 10:00 PM
rhino8648
Sep 6, 2015 04:04 AM
semlin
Jul 29, 2015 02:07 AM
