Rear Trunk/Hatch = Vibrates.
Old Jul 15, 2011 | 05:39 AM
TKTAB911's Avatar
Question Rear Trunk/Hatch = Vibrates.
I don't have a problem with the vibration of the windows, rear view-mirror or the side mirrors. Nor is there a problem for me in the car, but I took a step outside of my car today to find that the bass is so heavy from some songs, it shakes the trunk in tone. Not a big deal as far as license plate goes because i put two chunks of rubber between the plate and car to keep it from going crazy. Something inside of the trunk/hatch itself is causing a large amount of noise from 3 12" subs aimed to the center. I planned on dynamat -- lining the back portion of the car to help keep the bass more inward, but what I need is a guide and any needed tools to take off the interior parts of it and insert foam between the "plastic ribs" as this may be the cause [i've seen quite a few posts on the web about people doing this, although havn't found a guide].
Im sure the dynamat [or alternative for cheaper] will help this slightly, but I seriously doubt it'll be enough to truely make a difference.
*I've installed 270W Sony Xplods 6.1/2" Speakers in the doors without doing any damage other than cutting out the factory set/saving the mount without a guide of any sort. PS, should anybody follow the same, Gorilla Glue standard worked amazing. [[Im 17, so its somewhat of a proud moment ^_^]]
Old Jul 15, 2011 | 11:15 AM
highvoltage1's Avatar
Welcome to the tC! It rattles! Not much to say other than turn up the tunes! LOL
Old Jul 15, 2011 | 11:54 PM
vi3tb0i09's Avatar
Yea, I have the same problem. I did find a DIY on a fix for this way back when i just forget where. I'll see if i can find it for you. It might help you
Old Jul 16, 2011 | 12:07 AM
TKTAB911's Avatar
Alright vi3tb0i09, that would be helpful :]
Old Jul 16, 2011 | 12:08 AM
vi3tb0i09's Avatar
Found It. Here You go. Hope it helps
https://www.scionlife.com/forums/sho...&ref=ccm-ext-0
Old Jul 16, 2011 | 06:26 PM
jazfromhouston's Avatar
^I followed that DIY a while ago. That didn't do anything for my problem. I ended up finding another thread that mentioned putting down thick one sided sticky foam on the trunk bump stops. I did that, and have been vibration free for 6+ months. I'd try that first, as it's easier than the previous idea.
Old Jul 17, 2011 | 05:08 PM
vi3tb0i09's Avatar
But them You still have the problem? And you are right about the Dynamats. They will have little if not any effect on the rattling inside the car.
Old Jul 18, 2011 | 01:56 AM
HOLLOWMANGT69's Avatar
I recently just dyne matted by trunk. Still get the vibration at different tones with 2 10" subs. It is coming from the handle itself along with the license plate. Kind of hard to fix if you ask me.
Old Aug 2, 2011 | 09:13 PM
criminaltc's Avatar
Yo, there is not mat that will get rid of that rattle. that actual problem isn't the lid. its not the lid that's rattling, its the latch. a piece of duct tape around that plastic part behind it might help. get in the hatch and close it and watch that whole latch assembly rattle and you'll see what you need to tighten up to get it to stop. good luck. ive been there done that. try it out
Old Aug 7, 2011 | 06:56 AM
TKTAB911's Avatar
Cut out a 3mm thick strip of foam to wrap around the bracket that the trunk-hatch locks to, that cut down about half the sound. But that's plenty for me, since the bass drowns out most of the vibration sound.
Old Aug 7, 2011 | 11:59 PM
PRODIGY3000's Avatar
My 12's literally shook the stock 3rd brake light harness until it didn't function anymore. Take the hatch apart, and find anything around the latch area with any play in it. Wrap up anything you can with tape, and fill up any space with some foam tape like mentioned earlier. My biggest problem was the license plate which is the easiest fix. A crumpled up rag or some newspaper underneath it should do the trick.
Old Sep 1, 2011 | 02:32 PM
RA31925's Avatar
My rattle came from my trunk flexing on turns. It sounded like a shock bottoming out. I saw a thread here somewhere which had a 2 part easy fix. It may not fix your issue, since every rattle in the trunk area differs for each person on here. I removed the 2 plastic washers on the bumper near the hatch latch. The installed a rubber washer on top of the existing plastic ones. Ordered a new bump stop for the bottom of the trunk which lines up with the plastic washer on the bumper. These bump stops are actually a little longer than the stock ones. It was about $4-5 bucks depends on your area. Very cheap and easy fix.
Guess what this really worked. Ive been driving around with this sound since feb of 2005 and just got used to it. My sub also helped cancel out the noise. But for those folks who have not tried this, give it a shot. It is inexpensive and do not need to have tons of mechanical knowledge to do this.
Let me know how this worked out for you!.
wonderworm
Nov 19, 2023 01:44 AM
Inazuma
20
May 3, 2023 01:58 AM
toyotaisme
Jan 10, 2015 10:24 PM
PTUNING
Dec 11, 2014 08:09 PM
umnitza
Dec 1, 2014 06:26 PM
