Replacing Battery Terminals / Extended Battery Cables
Old May 23, 2014 | 02:27 AM
icestorm's Avatar
Default Replacing Battery Terminals / Extended Battery Cables
I have a 05 tC and it looks like it is time to replace the battery terminals. I have started to sometimes hear the 'click' after trying to start the car and it won't start.
I have not done this before and have been reading up on this a little bit. Would appreciate any feedback. I am thinking of extended the cables also while i am at it (solder).
I have bought 4 guage cables from KnuKonceptz along with the battery terminals. I think I will have the length of each to be about 1 feet. Is that going to be an issue ?
Negative cable seems easy to work on.
There seem to be two cables connected to the positive terminal of the battery. I would assume that I should just connect them both individually to the positive terminal instead of soldering them both together and then connecting to the terminal ? Where are they going to ?
Old Jun 2, 2014 | 01:16 PM
sciontc_mich's Avatar
couple of answers for you..
1- have you had a load test on the battery? A bad battery could definitely cause the "clicking" you're describing.
2- Extending the cables, in electrical work, always make sure that the power and ground are the same gauge. Extending a ground usually isn't that good of an idea. Electricity likes to get to ground as quick as possible.
3- The two wires coming off the positive, if you follow them, one of them goes to the starter, the other the fuse box/alternator connections.
Old Jun 23, 2014 | 01:41 AM
icestorm's Avatar
my battery seemed fine.
so i ended up extending both the cables and also changed the battery terminals. i used guage 4 cable for both the +ve/-ve which seemed to be thick enough. there were two cables coming out for both the positive and ground. i soldered the cables and then covered them with heat shrink/conduit.
has been almost a month now and i am happy with the results.
blh72
Scion xD Wheel & Tire
Feb 2, 2015 12:36 AM
ScionRo
Jan 2, 2015 07:54 PM
Thunder_xB
34
Jun 22, 2004 07:17 PM
rolex87
Feb 28, 2004 06:53 PM
o4_USDM_bB
Feb 9, 2004 04:06 AM
