Sound issues with my AVN6620! Help Please!
Old Jun 2, 2009 | 01:18 AM
shortthrow27's Avatar
Default Sound issues with my AVN6620! Help Please!
I finally installed my new Eclipse AVN 6620 in my tC today. No Amp or woofer hooked to it yet,just to the stock speakers with a Sirius tuner. Everything works great until you turn up the volume and then it starts cutting in and out (clipping?)Lower the volume down and its fine.Can somebody please explain to me what the hell is going on and why? From my understanding this can happen when a amp is pushed to its limits,well since I do not have it hooked to my amp or sub yet then what the heck? Any help would be great,Thanks in advance!
Old Jun 2, 2009 | 09:17 AM
Supa's Avatar
Ur wires r Tape correctly??????? or u went from Harness to Harness ??????????
Old Jun 2, 2009 | 01:02 PM
CarbonXe's Avatar
It plugs directly into the stock wiring harness.
I don't have this problem. But then again, I don't think I've gone over 50.
Old Jun 2, 2009 | 02:50 PM
It is all plugged in with the factory plugs. I have the Eclipse ECL-SC1 Sirius interface which also plugs into the big black connector that comes with one of the harnesses with the radio,power to power,and the ground is grounded to the same bolt I have the parking brake wire to.
Both Fm and Satellite radio does not even start to get loud until you turn up the volume to the upper 40's,somewhere after that is where it will start cutting out.If I choose a EQ setting with more bass or mids then flat it will cut out even sooner!
I'm confused and ____ed off to be honest this is why I don't like to mess with this kind of stuff.I swear everthing I touch sometimes turns to ____, I did not even install my Nine4 amp w/ the SQ10 stealth box yet
Old Jun 2, 2009 | 02:55 PM
CarbonXe's Avatar
Dunno, I have the same HU with the XM Adapter and iPod adapter and haven't had any problems with it.
Old Jun 3, 2009 | 01:05 AM
Do our cars have a amp somewhere in the car from the factory, or are the stock speakers just powered by the headunit?
I really wish I can find out what is going on cause its driving me nuts!
Old Jun 3, 2009 | 05:59 AM
dubberatheart's Avatar
I listen to mine at ~50 daily and have never had a problem like that
idriveanxa
Mar 8, 2015 12:03 PM
evolving_machine
Feb 27, 2015 09:53 PM
brownSys
Feb 27, 2015 04:20 PM
corbmonster
Jan 24, 2015 05:22 PM
cid_mcdp
Jan 5, 2015 02:45 PM
