sub amp HELP!
Old Oct 1, 2006 | 06:34 AM
chrischoi's Avatar
Default sub amp HELP!
so i wired everything correctly.. the sub works fine.. the amp should work... i plug everything up and nothing...
any ideas?
it's a jl 500/1
jl 10w6v2
alpine 9853 head unit
yes subwoofer is turned on on the head unit...
it's on f/r/swoofer for the x-over
everything is on in the amp...
i'm guessing it's the rca's or the amp itself. gonna find a voltage meter thing.. and check and make sure somethings coming through.. any advice?
Old Oct 1, 2006 | 06:37 AM
Yanki01's Avatar
nice setup, i have the same! You'll love it once you get it running?
Ummmm, i would say bad ground? 9/10 times its the ground! Sand the grounding spot really good!
Old Oct 1, 2006 | 07:04 AM
chrischoi's Avatar
even if the amp turns on?
Old Oct 1, 2006 | 07:12 AM
chrischoi's Avatar
if the amp turns on... it should work right? no matter how bad the ground is... if it turns on.. i would think it should work... what do youthink?
Old Oct 1, 2006 | 08:49 PM
MJVsTC's Avatar
Fix it yet?
Old Oct 1, 2006 | 09:32 PM
chrischoi's Avatar
no. 48 hours and no progress... yes everything is hooked up right... yes the amp powers on... ground is good... tried other amps and subs.... nothing.... so i'm guess rcas are bad? that is possible right?
Old Oct 1, 2006 | 10:41 PM
Yanki01's Avatar
are the RCA's in the right spot?
Old Oct 2, 2006 | 12:25 AM
chrischoi's Avatar
yes
Old Oct 2, 2006 | 01:04 AM
MountScion1's Avatar
Did you check that the speaker wires coming from the amp are in check with the polarity? I have a jl 300/4 and one of my speakers didn't work cause I had the polarity backwards....just a thought. Good luck...and definitely look over everything with a voltage meter.....
Old Oct 2, 2006 | 03:06 AM
defbrett's Avatar
Check the speaker wires inside the sub box (loose connection/s). If that's not it, then move on to the RCA cables from BEHIND the headunit (again, loose connection/s). If you have extensions for the RCA cables definitly check those (personal experince there).
Old Oct 2, 2006 | 03:19 AM
ESEMRFOZZ13's Avatar
mine did the same at first, i've got an mtx and JL set up. i used a power tester and found it best where the back of my stock deck is missing a wire harness for scions after market crap. i kept my stock unit, i do have an alpine also that kicks ___. it hooks up multi amps, xm, tvs, dvds, and has some bad a$$ features. pm me so i know exactly what you have and did, maybe i can solve your issue. i do my own set ups.
Old Oct 2, 2006 | 04:17 AM
chrischoi's Avatar
sub box - check
rcas - check
all wiring is good to go...
polarity is good... we checked everything and then we also reversed everything... still no reaction... the sub doesn't budge...
Originally Posted by ESEMRFOZZ13
mine did the same at first, i've got an mtx and JL set up. i used a power tester and found it best where the back of my stock deck is missing a wire harness for scions after market crap. i kept my stock unit, i do have an alpine also that kicks butt. it hooks up multi amps, xm, tvs, dvds, and has some bad a$$ features. pm me so i know exactly what you have and did, maybe i can solve your issue. i do my own set ups.
pm'ed
thanks for the help and advice... anyone else?
we also tried a different amp... no response... then a different sub... no response...
i'm guessing... something on the head unit... or... the rca cable is just bad.
Old Oct 2, 2006 | 10:29 AM
MJVsTC's Avatar
Do you have a CD in?
Old Oct 2, 2006 | 03:46 PM
chrischoi's Avatar
very funny matt.... yes i'm getting sound through the speaker but not the sub.... i'm about to become a tc hater in one second and trade it in for a camry... i'm getting tired of this dumb car. POS!
Old Oct 2, 2006 | 07:52 PM
nebster's Avatar
sounds like the headunit rca outputs are bad. bring it in to a dealer and have it tested out. thats the only thing i can see.
Old Oct 2, 2006 | 08:11 PM
UV7's Avatar
UV7
If you've tried other amps and subs in place of the JL setup and you still have the same issue, then you must be having an issue with the RCA's or a ground issue. Just because the amp turns on does NOT mean that your ground is a good solid ground. Have you had any blown fuses?
First, make absolutely sure your ground connection is clear. You need to grind away any and all paint from the connecting point. Clean the grounding point after grinding off the paint to ensure there is nothing to hinder your connection. Reconnect the ground.
If this has not fixed the issue, you need to verify the function of the RCAs and RCA cables. Do you have a spare set of cables to try? If so, try them. Switch the RCA cables from the sub pre-out to another pre-out set of RCAs. Anything?
It is highly doubtful that your Scion is the source of this problem. More than likely, it is an installation issue.
Old Oct 3, 2006 | 12:10 AM
chrischoi's Avatar
installation is fine.. .i had it at work.. had a bunch of the techs take a look... ground is good... we regrounded it...
rcas are fine... checked it with volt meter...
came to the conclusion... head unit settings?
Old Oct 3, 2006 | 12:13 AM
CsmTc_roller's Avatar
Is the amp turn-on wire getting power at the amp? You can check by running just a wire straight from the thick power wire to the turn-on wire spot on the amp.
Old Oct 3, 2006 | 12:15 AM
Makaveli's Avatar
i can almost guarantee your sub control is on 0. i think the default is on zero so it doesnt scare the ____ out of you. it is basically a gain control so since u have it at 0= no sound fool. put it on 15 and lets the good times roll. have fun
Old Oct 3, 2006 | 12:19 AM
Makaveli's Avatar
ps i can't believe your dealer has inexperienced installers....if u still havent figured it out, the sub output can be accessed by pressing the big ****. forgive me if im wrong
