sub/enclosure question... please read please help
Old Oct 20, 2005 | 10:20 PM
skizzle's Avatar
Default sub/enclosure question... please read please help
I have a 250w amp that will push my single sub...
would a 10" sub that handles 250w sound ANY different than
a 12" sub that handles 250w that is the same brand and class? (memphis PR104 or PR124)
SECONDLY,
My specs for enclosure say this....
1.00 cu ft / 1.50 cu ft
Use left value for lower power handling and the right for greater power handling....
this is for sealed enclosures.....well my sub handles 250rms and the amp puts out 250....so what would yall do?
1.00 or 1.50????
Or does it matter?!
Old Oct 21, 2005 | 01:13 AM
violent_b's Avatar
what size sealed enclosure are the 10" and 12" supposed to be in? if both subs are in their correct enclosures the 12" should play a little lower and give you a little more bass. I personally like to have a little more bass than needed because I could always turn the bass down.
Old Oct 21, 2005 | 04:55 PM
skizzle's Avatar
for the 10" it says...
.50 / 1.00 cu ft for sealed
for the 12" it says...
1.00 / 1.50 cu ft for sealed
and the part that confuses me is the line that says....
the left number is for minimum airspace with greater power handling...
the right number is for optimum airspace with less power handling...
SO... since i have a 250w rms sub and am putting 250w to it....
which one do i do? or does it matter?
Old Oct 21, 2005 | 04:59 PM
mandos's Avatar
Smaller box > power handling, less low end.
Larger box < power handling, more low end.
This is just mechanical power handling....basically, larger box, sub moves farther, easier to bottom. 250W is probably thermal handling.
I'd probably but it in a box right in the middle, give it 250, and it'll be good.
toronado
Oct 20, 2016 03:42 AM
yhwhdesign
Mar 7, 2015 02:01 AM
DougC
Feb 22, 2015 02:39 PM
stayintrucha
Scion tC 2G ICE & Interior
Dec 18, 2014 04:36 PM
Docsnuff
10
Dec 30, 2003 07:23 PM
