System advice, help needed.
Old Mar 19, 2007 | 03:03 AM
willingwelli's Avatar
Default System advice, help needed.
Ok, so my setup right now is:
Headunit: Eclipse CD3100
Speakers: 300 Watt Memphis audio components in front, stock pioneers in back
Amp: 1200 watt sony xplode
I have 2 12 inch subs my friend let me borrow, but my question is... can I run my speakers and subs off this 2 channel amp?
If not, would my front speakers powered up enough to run just off the headunit? Right now my gains on my amp are barely even turned up. If i can't run them both, I might just run the subs off the amp and keep the speakers powered by the headunit, but just wanted advice on which route would be the best.
Old Mar 19, 2007 | 03:08 AM
scion07's Avatar
speakers will have plenty of power if im not mistaken the headunit has a biult in amp prob 50 watt but just use the amp for the subs
Old Mar 19, 2007 | 12:21 PM
s0n1c's Avatar
Agreed, just use the amp for the subs. I have my speakers run off the stock unit and then my 10" on an amp, and the speakers are plenty loud. Since the stock unit can power the speakers, I'm positive that you can run the speakers off an aftermarket unit no problem.
EDIT: Plus to get the most out of your sub, you would need to use the LPF function on the amp which would take any decent sound out of the other speakers.
polychromaticfetus
Scion tC 2G Forced Induction
Sep 9, 2015 12:12 AM
ShawnMcc
Jul 11, 2015 11:07 PM
DaMax85
May 2, 2015 10:32 PM
Kata
Mar 2, 2015 10:46 PM
carid
Feb 9, 2015 01:49 PM
