TC AUDIO HELP
Old May 22, 2013 | 07:17 PM
ABehr's Avatar
Default TC AUDIO HELP
Hey guys I have seen there is ways to add a sub to factory radio but let me know if this would work. I'm wanting to add a sub a small 10" and a pair of 6X9s for some added audio. So can I add a 4 channel amp have two set for the 6X9s and bridge the Sub? Going to get a box made to hold 10" sub and both 6X9s I see there is adapters for amps to factory radio but I've read its for subs only Thanks.
Old May 22, 2013 | 09:22 PM
GQQSE13's Avatar
with a 5 channel you can but i do not believe a 4 channel
Old May 22, 2013 | 10:08 PM
ABehr's Avatar
Yes you can bridge the sub to the two unused channels just get the ohms right. I'm worried as to will it pick up the right frequencies for regular audio speakers the 6X9's?
Old May 25, 2013 | 01:11 AM
nitekillerz's Avatar
well you can do that. If the amp has two inputs you should be fine. Use one for front and one for sub. Adjust the settings with the crossover
Old Aug 3, 2013 | 04:19 AM
Morals's Avatar
Not all 4 channel amps are 3 channel compatible.
carid
Aug 7, 2015 11:32 AM
marsman328
Regional - Pacific Mid
Jul 28, 2015 09:43 PM
Beesh
Jan 9, 2015 06:30 PM
