tC radio door squeak
Old Dec 4, 2006 | 09:08 PM
  #101
cubano69's Avatar
1UP Crew
I just started having this same problem.
Old Dec 9, 2006 | 10:41 AM
  #102
summx's Avatar
Originally Posted by 05-RS1
hmm..i dont wanna super glue it cuz if it's moving and i glue it, somethin might end up breaking..mayb if i try lubricating it? so it'll move more freely?
i glued mine and its still good, the door still closes just fine as well.
Old Mar 30, 2007 | 03:39 AM
  #103
DAE51D's Avatar
I just took the plunge and attempted this fix. I could take it no more. Seems the squeek of death was getting worse every day. We'll see if it is gone tomorrow...
While I was at it, I moved my fog light switch to the left-most slot of the four. Not quite sure why they didn't do that by default. You can't see the right-most two slots with the steering wheel in the way.
Another thing that I find really troubling about this whole ordeal, is that SOOOO many people have it, I heard it on a rental tC while getting my lowering springs in, and a girl I know has it too, yet my dealer (Rodland Scion -- who sucks ___ BTW!) played it off like they had never heard of this and didn't know what I was talking about. that's BULL____. They need to own up to this and fix it right there while you wait. I paid $30k for my tC from the dealer with all the extras, and I shouldn't have to be tearing apart the dash to fix their defect.
Old Mar 30, 2007 | 03:43 AM
  #104
amanda776's Avatar
This fix works wonders. I used the first method and I've been squeak free for months now.
Old Mar 31, 2007 | 02:01 AM
  #105
DAE51D's Avatar
fastandcurious, dude, you are a life-saver! Today was the first time since last August that I could drive my car in peace, go over all the bumps I wanted, crank my stereo as loud as I wanted, and not have that brain-numbing squeek.
::praise::
Old May 7, 2007 | 06:18 AM
  #106
kalfin2000's Avatar
<3 fastandcurious that squeak was driving me mad! lil tape was all it needed i used double sided poster tape, same thing. now i need to fix the gouge in the silver paint in the dash from my previous attempt at fixing the squeek
Old May 10, 2007 | 03:03 PM
  #107
Nychold's Avatar
Holy crap!! I've been hearing that squeak ever since I drove off the lot, and no one has been able to fix it! Not Toyota, not BB (where I had my Alpine installed), no one!
I'm so trying this when I get home...now where can you get that 3M adhesive?
Old May 10, 2007 | 08:17 PM
  #108
DAE51D's Avatar
Anywhere. Your local supermarket should sell it, as would a hardware store or drugstore. I just used the little squares. But I suspect you can use most anything, even a wad of tissue paper taped in. You just want to prevent the plastic from rubbing.
Old May 10, 2007 | 08:26 PM
  #109
Nychold's Avatar
Cool, thanks! It's a lot better than my solution.
Now to fix what I broke from pounding on the A/C vent.
Old May 21, 2007 | 11:37 PM
  #110
fastandcurious's Avatar
wow, i didn't know people were still posting in this thread lol. i'm very happy to hear that this fix is still helping tc owners. it really does stink that we have to deal with this, but at the very least there is a solution.
Old May 22, 2007 | 12:28 AM
  #111
Nychold's Avatar
Well, mine isn't quite fixed. Think I messed it up, but when I get a chance again, I'll rip it apart, and see if I can't get it to work. Thanks though!
Old Jun 28, 2007 | 12:49 PM
  #112
Menace's Avatar
Anyone know where I can find all the TSBs. The more I own the car the more everything seems to rattle, I have '06 and I heard there are TSBs to some of these.
Old Jul 4, 2007 | 08:16 PM
  #113
11thhour's Avatar
works like magic
Old Jul 21, 2007 | 04:35 PM
  #114
mdkflip's Avatar
Default All you need is foam, foam is your friend
The method I tried worked perfectly. I had a high pitch chirp sometimes from the center console. I never figured it out until I came across this thread. I ended up putting a few pieces of foam underneath the two vents. After that never had that noise come back. AWESOME!
Now I just have the deal with the rattle coming from the back, but I will deal with that when I put in my third tail light and license plate lights.
Old Jul 27, 2007 | 10:40 AM
  #115
sciontc_mich's Avatar
I know what fastandcurious did was mounting tape, just wanted to know if rubber foam tape for weather stripping would work too? Or do you need something harder to separate the plastic?
Old Jul 27, 2007 | 06:39 PM
  #116
DAE51D's Avatar
I'm pretty sure the idea is anything to prevent the two pieces of plastic from touching. I think weather stripping should be fine too as long as it stays there. Just tape it down with some electrical tape or duct tape or something.
Old Jul 28, 2007 | 12:00 AM
  #117
okay thanks.. yeah was thinking it should be something that stays there and doesn't move. and you are right, about foam tape moving. that's probably what fastandcurious went with the mounting tape, more rigid and stays put.
cool.. thanks for the reply!
Old Sep 3, 2007 | 07:05 PM
  #118
FLINTstone's Avatar
BACK FROM THE DEAD!!!
i searched for this thread because the same noise was driving me nuts!after examining the HVAC a little i found a better solution to the squeak problem.
in fastandcurious' pictures, you can clearly see where the squeak comes from. this little rod rubs and squeaks against the housing it sits in.
in this image you can see the dust left behind from all the friction of those pieces rubbing together!!! what we wanna do is eliminate that friction! no friction, no sound.
the answer is simple. take a cotton swab, swab a little plastic lube (petroleum jelly works fine) and swab it onto the little pinion. press down on the vents so it sticks out all the way, and make sure to lube the whole piece. do the same to the other side and you will never hear that squeak again!
Old Nov 1, 2007 | 10:01 PM
  #119
GQQSE13's Avatar
i used some wd-40 type stuff on the hinges of the door.
Old Nov 2, 2007 | 11:00 PM
  #120
andino's Avatar
i used the fix where you put some tape between the vents and no more squeaks! yay!
