tc won't start help
Old Dec 16, 2006 | 08:49 PM
matt593tc's Avatar
Default tc won't start help
i recenty added some guages to my tc and touched the ground and a posotive wire to geather and now the car won't stat. the wires from witch i got the power sourse for gauges under the dash. the ony thing that works is the dash lights head lights brake lights... No wipers no radio no windows no heat no nothing. I checked all fues under hood and all under dash all were good. DID i miss one somewhere is there a main fuse? could it be a relay or what is it?
Old Dec 16, 2006 | 10:00 PM
KINGxOFxSKA's Avatar
Unique Scionikz
Do you have an aftermarket alarm? If so check the fuse for that and make sure is not blown... that could be preventing yer car from starting. Thats the only thing I can think of if all the other fuses are fine.
Old Dec 16, 2006 | 10:46 PM
sddykstr's Avatar
It's probably a fuse, donno which, but sounds like a fuse.
Old Dec 17, 2006 | 12:14 AM
SquallLHeart's Avatar
fuse go kaboom... i would go over all the fuses again if you didn't double check them
can you be more specific as to which two wires you shorted together? that would help out alot.
Old Dec 17, 2006 | 12:19 AM
shareindie's Avatar
Are you Pushing the clutch in?... jk i hope its just a fuse
Old Dec 17, 2006 | 12:39 AM
matt593tc's Avatar
yeah i found the problem it was a fuse that i had over looked 10 times, its just the little things that ____ ya off ya know.. its a good thing the car is up for the winter or my day would have been shot. thanks
Old Dec 17, 2006 | 01:26 AM
yup... there ya go... it happens.
fuse go byebye
Jordly221
Feb 13, 2019 05:29 PM
Mhawkins65
Mar 18, 2015 03:16 AM
mw1957
Mar 16, 2015 06:00 PM
cid_mcdp
Jan 5, 2015 02:45 PM
scionspecialistvegas
Dec 15, 2003 11:21 AM
