wiring for hazard lights?
does anybody know where i can find the wiring and color of the wire for the hazard lights? i have a viper 690xv installed in my car and it flashses the parking lights when it arms and disarms. i want to flash the hazard or run a relay to flash both parking and hazard. any help?
this is all the info i have for the tC
12volts
red (30A), white (25A)
ignition harness
Starter black + ignition harness
Second Starter green + ignition harness
Ignition blue + ignition harness
Second Ignition yellow + ignition harness
Third Ignition N/A
Accessory gray + ignition harness
Second Accessory N/A
Keysense black - ignition harness
Power Lock green to blue - driver kick, 20 pin plug, pin 15
Power Unlock purple to pink (double pulse) - driver kick, 20 pin plug, pin 14
Lock Motor blue to brown 5wi driver kick, gray 7 pin plug, pin 6
Unlock Motor pink to blue 5wi driver kick, gray 7 pin plug, pin 5
Parking Lights+ brown + top of fuse box, 30 pin plug, pin 29
Parking Lights- brown - headlight switch
Hazards orange - hazard switch
Turn Signal(L) yellow + top of fuse box, 30 pin plug, pin 27
Turn Signal(R) green + top of fuse box, 30 pin plug, pin 28
Reverse Light pink + top of fuse box, 14 pin plug, pin 2
Door Trigger orange (D), blue (P) - top of fuse box
Dome Supervision blue - L side of fusebox, 6 pin plug, pin 2
Trunk/Hatch Pin purple - top of fuse box, 30 pin plug, pin 7
Hood Pin N/A
Trunk/Hatch Release orange - driver kick, gry 12 pin plug, pin 12
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black ac data link conn. under dash, pin 9
Wait to start N/A
Brake Wire blue + brake pedal switch
Parking Brake black - parking brake switch
Horn Trigger white - steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass Module
MAKE : SCION | MODEL : TC | YEAR : 2005
add, for audio....
Radio 12v blue + radio harness
Radio Ground brown - radio harness
Radio Ignition gray + radio harness
Radio Illumination green + radio harness
Factory Amp Turn-on N/A
Power Antenna orange + radio harness
LF Speaker +/- pink - purple +,- radio harness
RF Speaker +/- lt. green - blue +,- radio harness
LR Speaker +/- brown - yellow +,- radio harness
RR Speaker +/- red - white +,- radio harness
acc....
LF Window up/dn yellow - pink A driver window switch in door
RF Window up/dn yellow - green A passenger window switch in door
LR Window up/dn N/A
RR Window up/dn N/A
Sun Roof open/close motor part of module
Sun Roof Limit/close N/A
12volts
ignition harness
Third Ignition N/A
Hood Pin N/A
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
add, for audio....
acc....
LR Window up/dn N/A
RR Window up/dn N/A
the flashing of the hazards wont work right....
the pulsed output from the parking lights will mess up the flaser for the hazard...
you need to use a constant when alarm is triggered...
IMO, it will look dumb to have bothe sets of light flashing....
You would need to have a constant +12V output from the alarm to feed into the hazard light circuit not a pulsed output. The circuit for the hazard lights has it's own integrated flasher wired in... so the end result will not really look all that hot. The hazards won't be synchronized with the parking lights... they will look more random.
You could do it by tapping the siren output wire (+12V) and feeding it into the hazard light button wiring harness. I am assuming that the trigger for the hazards is positive... if it is a ground-actuated trigger then you would need to use a relay to reverse the polarity on the siren output wire feeding into the hazard circuit.
Just finished wiring up a friend's line out converter for an amp/sub install on his tC. Since there is no writing on the wire and it follows no real wiring convention I know of... I figure I'll try to clear it up a bit.
2005 - Scion tC Stock Head Unit wire guide.
Looking at the head unit from the rear, there are two plugs on the right side and two empty sockets on the left. On the far right is a big plug with lots of wires, we will call this Harness A. Just to the left of that but still on the right side of the head unit is a smaller plug with about 5-6 wires comming out of it, this we will call Harness B.
Harness A Wires -
Radio 12v blue - On the far right side bottom IIRC
Radio Ground brown
Radio Ignition gray - Tap this one to control amp power via the remote wire.
Power Antenna - orange - Does this actually do anything?
LF Speaker Pos. - Pink
LF Speaker Neg. - Purple
RF Speaker Pos. - lt. green
RF Speaker Neg. - blue - Looks identical to the 12v, but on the left side below the light green RF Speaker Pos. wire.
Harness B Wires -
small white wire comming out of the middle???
LR Speaker Pos. - brown
LR Speaker Neg. - yellow
RR Speaker Pos. - red
RR Speaker Neg. - white - lower gauge (thicker) than the other white one mentioned above.
Aside from the coloration of the wires the only markings are silver dots every couple of inches or so, all the wires save one have single sliver dots, one, the small white one on harness B as I recall has 2 silver dots.
Harness A Wires -
Radio Ground brown
Harness B Wires -
ok i really need help on this one guys!! i too bought the line out converter for my amp so that i can use the stock HU and i followed danbs wiring but i really cant make much sense of it. it says LR and LR?? shouldnt it be LR and RR and LF and RF?? someone please help becuase i installed it
I would also like to know what the aux input wiring for the 06 looks like. Trying to use the 06 head in an 05. Sure would be nice to have the feature of aux input since the head allows for it.
thanks
thanks
any one help me i have scion tc modle2005, i m staying in united arab emirates, so the radio is not tuning the FM frequncey 0.05MHZ but it tune USA standerd 0.3MHZ how to change the tuning to manul and auto or to world regen tuning. thanks
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
missing_image
Feb 7, 2015 07:18 PM
Green_rino
Scion FR-S ICE & Interior
Jan 20, 2015 01:41 AM
randode
44
Jun 29, 2004 04:19 PM
