High RPMs on Start Up?
Old Apr 19, 2005 | 11:55 AM
BreakTheStatic's Avatar
Default High RPMs on Start Up?
Hi everyone, I just purchased a FM tC on Saturday and it is my first standard transmission. I'm doing alright with the shifting, but my question relates to starting. When I start the car up the rpms stay in the 2k range for a few seconds and then settle down to around 1k. At the dealer it started normally and the rpms were around 6-7 hundred. Is it normal for the engine to run that high when starting the car in the morning. It's about 48-50 degrees here right now.
Old Apr 19, 2005 | 11:56 AM
3_IGs's Avatar
yup, perfectly normal.
Congrats on the tC.
Old Apr 19, 2005 | 12:06 PM
Smokin's Avatar
Its normal.
Old Apr 19, 2005 | 03:31 PM
terra_tC's Avatar
its perfectly normal for ANY toyota engine during a cold start. The one at the dealer was probably already warmed up....
Old Apr 19, 2005 | 03:37 PM
Thanks guys for the input. I know that usually most cars rev higher during cold starts, but I wasn't sure if 2200rpm was too high. Really thanks a lot for the info. I love the car so far btw :D
Old Apr 19, 2005 | 03:42 PM
epitek's Avatar
that initial higher rev is standard for most cars, if not all. its there so that the engine can warm up faster. if you had an automatic, you'll also notice that it shifts slower and stays in a higher engine RPM range. its all so that the car warms up faster.
Old Apr 19, 2005 | 04:26 PM
scoobyroo2002's Avatar
Yeah...when your starting it though..make sure you put it in nuteral he he he i made the mistake of forgetting to put it in nuteral and the car jumped foward and died ...thank god for the e-brake otherwise scion would have met wall!
Old Apr 19, 2005 | 05:11 PM
fivepointnine's Avatar
done it on every car Ive ever owned.
Old Apr 19, 2005 | 05:58 PM
xnevergiveinx's Avatar
yeah, the rpm is pretty high at startup. also, don't be alarmed if for no reason, the rpm jumps around when your waiting for it to warm up, it just does that
Old Apr 19, 2005 | 06:26 PM
GeoffreyS's Avatar
Dosent our Tcs' have a neutral safety switch??
Old Apr 19, 2005 | 06:29 PM
Not if you let the clutch out thinking it's in nuteral...then it goes BOOM..then turns off..HE HE HE OPPS!
Miqmiqmiq
Apr 16, 2016 02:34 AM
MRE
Feb 16, 2016 11:26 PM
ERZperformance
May 13, 2015 11:36 PM
mw1957
Mar 16, 2015 06:00 PM
eric_m
79
Mar 17, 2013 12:21 AM
