low tire pressure indicator problem...Help!
About 3 months ago, I had my wheels rotated by a local shop. Soon after, the Low Tire Pressure indicator light came on. I rechecked the pressures and reset the light when the tires cooled off. It worked for about a week and it came back on. Did the same thing and it worked until last week. I reset it and tonight it came back on!
Anyone have any ideas on what could be the problem? I'm at 32k miles so I guess I'm out of warranty, so I'd like to avoid going to the dealer and have them charge me up the ___ for some simple fix if there is one.
hmmm... when that happened to me along time ago.. i rechecked the tire pressures.. and when you reset it.. make sure to hold it until to see all the blinkys go away.. (should be 3 times) some people don't hold it long enough.
sIcKsCiOnS
DelMarVa
Scion Tuners
basic warranty is 3yr/36k
if sensor was bad, that would be covered
its either a sensor or you may have a nail in the tire
the valve stem could also be leaking too
haha i had the same problem when the dealer rotated my tires, all you have to do is reset the senor PROPERLY which means holding the button down while the key is on acc for more than 5 secs and it should start to blink after its done blinking you should be good to go
...and once more, the sensors do NOT detect pressure in any tire, they detect the difference in rotational speed between tires. If a tire's pressure is appreciably lower or higher than the pressure in the others, it will rotate at a different speed.
But yeah, the commonest failure is the failure to do a complete and proper reset.
sIcKsCiOnS
DelMarVa
Scion Tuners
Dave, subject of topic: low tire pressure indicator problem...Help!
I'm just trying to get acrosss the way the sensors work so there is some understanding by most people that it is not 'low tire pressure' that sets off the 'tire pressure warning light,' but anything that causes one tire to rotate at a different rate than the others.
Doesn't change the correctness or accuracy of your answer, or the understanding of the question, just trys to assist in the general understanding of what the indicator is indicating for those who don't know.
While there ARE systems that actually monitor tire pressure, this isn't one of 'em.
Enjoy!
Enjoy!
Thanks for all the input! I did do the reset correctly, so if it happens again, hopefully it'll happen within the next 4000mi.
Should I do the soapy water trick on the valve stems to see if there is a leak?
DaBlackBox
134
Apr 10, 2022 02:04 PM
Sooby
Scion tC 1G Wheel & Tire
11
Apr 8, 2020 11:51 PM
kingofthecrate
Jan 21, 2015 09:28 PM
