Removing front rotors
Old May 27, 2010 | 07:30 PM
sciontC's Avatar
DeepSouth Scions
Default Removing front rotors
I just called a garage because I wanted to have my rotors replaced by someone other than the dealer to save money... The man said the job to replace the rotors and breaks would be 55 in labor, which im great with, however he said as hes not familiar with how they are on the tC, it could range from 55 to 150 in labor if he has to remove some type of wheel bearing or some type of bearing...
Does anyone have any idea if removal of some type of bearing is necessary for the two front rotors? This will make a big difference to whom I choose to take it to, thanks.
Old May 27, 2010 | 08:08 PM
crg5990's Avatar
nope. i replaced my rotors myself and all it takes is removing the wheel and caliper, and then the rotor just pulls right off.
Old May 27, 2010 | 08:12 PM
soldiercontreras's Avatar
https://www.scionlife.com/forums/scion-tc-1g-suspension-handling-1615/diy-brake-pads-rotors-caliper-painting-bleeding-93865/
Old May 27, 2010 | 08:39 PM
sciontC's Avatar
DeepSouth Scions
wow...I might actually try this myself then...thanks guys
Old May 27, 2010 | 08:44 PM
thendawg's Avatar
Unless the rotor is rusted to the hub - than you must enlist some pb blaster and a hammer - or a sledgehammer in my case Who cares about bangin up the old rotors - they arent going back on anyways
Old May 27, 2010 | 09:16 PM
GQQSE13's Avatar
i was a newb when i did mine and was pretty easy; jsut remember that jack stands, wd-40 and rubber mallet (to hit the socker to break the bolt loose) are your friends
Old May 27, 2010 | 10:33 PM
yellowxhoodie's Avatar
if your mechanic is asking YOU questions about how to do the work...
maybe its time you find a new mechanic.
just sayin.
i wouldnt trust something with my car if they were asking me questions like that.
Old May 27, 2010 | 11:30 PM
Macavely's Avatar
just sayin.
So true.. This is something he should know.. Most toyota are the same, If he asked something like do you have aftermarket brake system, or do you just want the front and backs done.. I would wouldn't go to that guy.. but then again I would do all the work myself.
good luck.
Old May 27, 2010 | 11:57 PM
Yeah it's super easy man. I had never messed with brakes before, but I just used the guides of people online and success.
SkillFreeJake
Scion tC 2G Aero & Exterior
Jul 27, 2015 12:34 AM
TotalChaos
Apr 7, 2015 09:02 PM
10gxiong
Feb 21, 2015 12:53 PM
carid
Jan 22, 2015 12:49 PM
kleecker
Jan 9, 2015 02:26 PM
