Running power lines to trunk
Anybody have a good method of doing so?
I am going to install an infinity basslink in the same position the stock sub would be.
I took a brief look and it looks pretty tight in the motor compartment.
Looks like I have a good couple of hours of work to run wires.
Any suggestions?
Any suggestions?
Well you could follow where the wiring is for the stock sub. I assume you'll be tapping the electricity off of a fuse or something, so run it through the dash to the passenger's side (might have to take off the center console and the glove box to see what you're doing. Then run it along the passenger's door jamb (it just pops off on the bottom) and then behind the plastic piece on the lower wall in the back seat. Pull out the rear seat (also just pops out if you pull right) and you'll be able to see how to run it past it. Then you can run it through the little compartment and have it pop out the rear bulb cover door, right where you'd want it for the sub. Just get the instructions for the stock sub installation, take your car apart the same way, and run the wire.
mischadoll
Mar 9, 2015 05:48 AM
missing_image
Feb 7, 2015 07:18 PM
George
Regional - Pacific South
200
Feb 11, 2006 01:48 PM
