Best Suspension Mod --> Improve Performance?
Old Jun 16, 2005 | 05:22 PM
Hondu's Avatar
Default Best Suspension Mod --> Improve Performance?
What is the best suspension mod to improve performance without using lowering springs (I don't want to lower the car). From what I read maybe Hotchkiss sways? New struts/shocks with stock springs? Need serious opinions only please.
Old Jun 16, 2005 | 05:26 PM
Onikage's Avatar
Good stuff:
https://www.scionlife.com/forums/viewtopic.php?t=67670
Old Jun 16, 2005 | 05:27 PM
malina's Avatar
Why would you not want to lower your car? Just asking, I personally think the car sits waaay to high on stock springs and looks weird. I have the hotchkis sways and they make a huge difference.
Old Jun 16, 2005 | 05:42 PM
Hondu's Avatar
IMO the tC looks great w/o lowering, and I'm not sure if I like the lowered look, but thanks for the feedback.
ack154's Avatar
My thoughts would be rear sway bar would be a good start. Then front sway/springs/shocks, then maybe a strut tower bar.
Old Jun 16, 2005 | 05:50 PM
Erni3's Avatar
One reason for me not lowering my car is all the flooding that happens in the houston area from time to time. If my car had been any lower than stock i would have already suffered flood damage.
Old Jun 16, 2005 | 06:09 PM
yellot00tr's Avatar
get the hotchkis sway bars. honestly, there isn't anything better anywhere. i had the trd setup. it's seriously going to another level with the hotchkis set. talk to anyone who has them. they'll tell u the same thing. i don't know how many people have had both the hotchkis and the trd, but i did. best decision i ever made-getting rid of the trd to go to hotchkis.
Old Jun 16, 2005 | 06:15 PM
boostedscion's Avatar
If you want the best for now. Get the teins SS or Basics and use the sways Hotchkis provides and the struts from Trust or whereevers.
Old Jun 16, 2005 | 06:41 PM
matty-tC's Avatar
2" makes THAT much of a difference????
johnnyTCblaze's Avatar
Don't mean to get into another topic but, who has better sway bars? Hotchkis or TRD? Or are they the same because they're just sway bars?
Old Jun 16, 2005 | 06:43 PM
matty-tC's Avatar
hotchkis are stiffer
Old Jun 17, 2005 | 02:54 AM
brownbanana's Avatar
Progress also makes Rear sway bar for us
Old Jun 17, 2005 | 05:34 AM
Joe_Dezod's Avatar
Bars are meant to aid the performance of the springs and struts. They shouldn't be used as the primary defense against body roll.
I'd recommend buying Progress C1 coilovers (from what's available right now) and leaving them at a close to stock height. You may lose half an inch in height, but the performance will still be much better. You have stock sways meant for stock springs. If you upgrade the sway bars and leave the springs stock, it the physics will be off and the bars will act as a spring in it's own, but without damper. Kinda weird to get into, but I hope that helps.
Old Jun 17, 2005 | 05:49 AM
killerxromances's Avatar
Without using springs or coilovers? You won't get the max out of anything you do to the suspension without a lower center of gravity.
front + rear strut bars; front + rear sway bars; shorter performance shocks will help a lot but you won't get the full improvement without lowering the car..Coilovers if you want straight up performance, springs if you want a little more performance handling but don't feel like spending $1,000K right away..Or if your like me, and just dont have the money for coilovers right now.
Tanabe DF210 springs are by far the best IMO.
For Coilovers, HKS or JIC but both companies don't have Tc stuff out yet.
So Progressive or Tein.
Good luck!!
Old Jun 17, 2005 | 04:47 PM
JasonH's Avatar
For better handling, start with stickier tires. After that, in order of most improvement to least: TRD rear sway bar (or Hotchkis set), then springs, then struts.
Old Jun 17, 2005 | 05:56 PM
Mr_Meaty's Avatar
The best thing you can do is get grippier tires. Then the Hotchkis sways. Much better then TRD cause it's alot stiffer and it's front and back. They made alot more differnce then the TRD springs did, but you may consider those as well because they only drop about 1.2 inches and add some stability. Then shocks.
carid
Feb 12, 2015 11:54 AM
jaspercanda
Dec 22, 2014 09:35 AM
eric_m
79
Mar 17, 2013 12:21 AM
eric_m
25
Oct 18, 2003 12:33 AM
