cons of coilovers (i heard) are they true?
Old Jun 1, 2006 | 02:16 PM
Revilo's Avatar
Default cons of coilovers (i heard) are they true?
i heard that the coilovers would rub with the sway bars... is that true? it is bad?
Old Jun 1, 2006 | 02:27 PM
dgHotLava's Avatar
certain combinations of sway/coilovers do cause rubbing issues.
Old Jun 1, 2006 | 02:29 PM
Revilo's Avatar
for example the hotchiks? (which one? front or rear?)
Old Jun 1, 2006 | 02:30 PM
Harmonic_tC's Avatar
my tein ssps rub the steering arm against the stock swaybar under full lock left or right and only if they are either compressed or flexed. all you need is shorter swaybar endlinks.
Im going to be cutting mine and rewelding them back together with a sleeve around them for strenth
Old Jun 1, 2006 | 02:44 PM
Revilo's Avatar
which sway bars are the best combination for the teins?
Old Jun 1, 2006 | 02:53 PM
I dont know, I have the stock ones on and i like them enough to not change them at this time. I already have no body roll unless i take a corner HARD but at that point, im more worried about my stock tires breaking loose than anything else
Old Jun 1, 2006 | 02:58 PM
Revilo's Avatar
if the sway bars only help in the hard cornering? so... if I dont plan to cornering, the stock ones are ok?
Old Jun 1, 2006 | 03:04 PM
HKSpeed's Avatar
my tein SSPs rubbed against the front stock swaybar at full lock turns. this happened only at slow 3-pt U turns, not regular driving.
after i raised it up a little, the rubbing went away. I'm about 2-2.25 inches dropped.
Old Jun 1, 2006 | 03:13 PM
for my application the stock bars are fine.
Also, i have my coilover set at the height from the factory. I have not changed the height at all. but i like the height so im leaving it and modifying the stock sway bar
Old Jun 1, 2006 | 05:05 PM
DuMa's Avatar
cost is the only con
Old Jun 1, 2006 | 09:30 PM
atodak's Avatar
How does the cold/ winter effect CO's?
Old Jun 1, 2006 | 11:24 PM
ICrazyChrisI's Avatar
For some people, they got sqeaking noises while they were cold.
Old Jun 1, 2006 | 11:45 PM
kungpaosamuraiii's Avatar
The sway bar rubbing issue is entirely drop dependent. If you get rubbing at full lock, just raise the car up a little.
greytc
Oct 26, 2015 07:53 PM
mcnick0495
Scion tC 2G ICE & Interior
Sep 8, 2015 02:58 PM
ScionDP
Sep 8, 2015 02:17 AM
alexbarspin
Sep 3, 2015 02:04 AM
5N1PE5
Aug 3, 2015 11:25 AM
