cutting wheel studs?
Old May 13, 2011 | 03:28 AM
Mos_Def's Avatar
Default cutting wheel studs?
is it safe to do? i have 10mm extended studs in the rear because i had 10mm spacers in the rears. i upgraded to 15mm spacers with the studs already pressed in. my problem is that my 10mm extended studs touch the back of the wheels. it seems like the spacer sits flush with the wheel but i dont want to risk the wheel not seating properly with the spacers because of the extended studs. so cutting them shouldnt be a problem right? i plan to cut about 5mm. enough to give the wheel some room and still more than oem length. thanks for the input guys.
Old May 13, 2011 | 05:28 AM
Eziekel's Avatar
go ahead and cut them. you'll be fine.
Old May 13, 2011 | 03:13 PM
carben100's Avatar
It should be fine, but be careful not to damage the threads.
bbsciontc
Scion tC 1G Wheel & Tire
Aug 19, 2019 01:46 AM
Deves
Feb 8, 2015 11:37 PM
BManAmericae
Jan 18, 2015 12:17 PM
Slopoke21m
54
Apr 23, 2007 12:25 AM
TheRedBox
Feb 3, 2005 02:00 PM
