Front Caster Adjustment?
from what I know, i don't think they have adjustable lower control arms. If you've hit potholes, could've bent the control arm and that's why it's giving you those out of spec numbers. What are the numbers the alignment rack is giving?
Also, make sure to torque down all the bolts holding the suspension onto the subframe. There are a lot of them. that could make a difference in the readings as well
No, there is no front caster adjustment on our car, but if you loosen the bolts on the strut and push and pull it like if you were adjusting camber, then your caster will also move, and could move within specs....let me know if that sounds confusing...lol...
evolving_machine
Oct 21, 2023 01:16 PM
fluxingnation
Dec 26, 2014 04:28 PM
