How bad are my alignment check results?
Originally Posted by foreverandaminute
okay, so they fixed everything but the "Cross SAI"
...does anyone know what that is? and how bad is it if it's out of spec?
http://www.ingallseng.com/terms.htm#...%20Inclination
and another link here
http://autorepair.about.com/library/...bldef-748a.htm
and a good graphic here, gotta scroll down for SAI
http://redirectingat.com/?id=42X122&...%2520%28SAI%29
basically it is probably because the car is lowered changing the kingpin axis from where it was when stock. Nothing to fix with SAI or Cross SAI (difference of SAI from left-right)
Nothing to worry about though. Since there isn't anything you can do, because all the other numbers (caster, camber) look good and within spec.
+1 on engi, yet again.
You could theoretically run up to 4 or 5 degrees of camber before you drastically impact tire life. On my uncle's Reilly, we dial in about 2.5 - 3* before each race, depending on where we are. Then again, this is a purpose-built race car that goes through 2 sets of sticky tires in each 3 hour session.
But hey, not like you can actually dial that in on a stock setup.
Running 1 degree of toe will chew up your tires in less than half the time. On the scion, I run dead-ahead at the rear, and within factory specs at the front.
I would like to be able to quickly and easilly dial in a degree or so of toe on mine for autox events. Actually, you can mark everything properly and do it. But, as you said, it would be pretty harsh on tires on the street, not to mention it would handle in almost a scary fashion at highway speeds
can range anywhere from 80-120+. some places do it by set price regardless if dropped on aftermarket stuff or not. some do a base price + price per axle if you have aftermarkets...mine was 110. 70 base + 20 for 2axles + 10 for aftermarket lowering + tax = ~110
look for a firestone complete auto care center near you:
http://www.firestonecompleteautocare...cate/index.jsp
they offer lifetime alignments for the price of 2 or 3 alignments (price varies for each shop)
sciontc_mich, thank you very much!
I dont align to oem specs (most autoxrs dont) so the firestone option is no good for me since shops like that align only to oem spec. I go to an alignment guy that charges less than half what other shops do for oem spec alignments and about 85 or so for a non oem alignment, depending on how much work it takes of course.
kleecker
Jan 2, 2015 08:09 PM
Strader
25
Jul 22, 2004 09:27 PM
Carson_Scion_TRD_Parts
Dec 30, 2003 09:29 AM
Docsnuff
9
Nov 23, 2003 09:50 PM
