Ksport Kontrol Coilovers info needed.
Old Mar 19, 2009 | 11:03 PM
  #141
livefastdiefun21's Avatar
i finally got my d2's and from my eyes its the exact same coil over im havin problems with the front strut the peice in the middle that mounts the sway bar i guess. i have it mounted but it just doesnt seem mounted correctly or atleast moving smooth
Old Mar 20, 2009 | 05:11 AM
  #142
blackcherry07's Avatar
hmmm more detail about your problem...probly the same one dq had...
Old Mar 20, 2009 | 08:46 AM
  #143
dqlostsoulz's Avatar
so what is it doing that is not right? Did you unbolt both sides before you mounted it? Because I had that problem because I was trying to bolt up one side without unbolting the other side first. You got some pics maybe that would help out better.
Old Mar 21, 2009 | 01:03 AM
  #144
i got them to move up now just tryin to find a good place to bolt them at.. is there a good place to adjust them or just put them where it rubs nothing
Old Mar 23, 2009 | 01:18 AM
  #145
Old Mar 23, 2009 | 04:15 AM
  #146
got them on finally doesnt look to bad check out my new pic
Old Mar 24, 2009 | 01:05 AM
  #147
looking good. are the fronts lower than the rear? Did you remove any rings??
Old Mar 24, 2009 | 04:03 AM
  #148
i removed one ring in the back.... and ya the fronts lower it sucks im still tryin to figure out a way to get the back lower any ideas...
Old Mar 24, 2009 | 05:54 AM
  #149
Look on pg. 6 blackcherry07 and I had a discussion about that.
Old Mar 25, 2009 | 08:33 PM
  #150
djtc's Avatar
where is the best place to buy the ksport kontrol coilovers??? im looking but im finding them at pretty high prices.....
Old Mar 25, 2009 | 09:36 PM
  #151
I cant help you there playa. I just looked threw the classifieds and ebay. I actually brought mine from an SL member for a pretty good price.
Old Mar 26, 2009 | 01:12 AM
  #152
same here....somewhere had a good deal on them at one point but i cant remember where
Old Mar 26, 2009 | 03:06 PM
  #153
ksport-878
d2-850
http://www.ultrarev.com/product.php?productid=42584
http://www.weaksauceparts.com/store/home.php?cat=1401
what do u consider cheap.... pretty much same exact coilovers...
Old Mar 27, 2009 | 01:14 AM
  #154
I noticed my ride is pretty bouncy at times. Any suggestions to what it might be??
Old Mar 27, 2009 | 01:25 AM
  #155
bouncy or rough....i have no isssues with mine....
Old Mar 27, 2009 | 01:26 AM
  #156
It bounces at times like if I am hittin some switches.
Old Mar 27, 2009 | 01:33 AM
  #157
yea...maybe stiffen up the dampening a little...what do you have it set at?
Old Mar 27, 2009 | 01:42 AM
  #158
I have the rear about 3 full turns and the fronts at 2 full turns.
Old Mar 27, 2009 | 01:58 AM
  #159
hmm....what feels bouncy...the front or rear?
Old Mar 27, 2009 | 02:05 AM
  #160
The whole car., but its only at times. I dont know if maybe i tighten the perches to the springs to tight or what?
