Lower ball joint issue
Old Feb 24, 2010 | 02:35 AM
dookie1427's Avatar
Default Lower ball joint issue
Just wondering if anyone out there has had to replace their lower ball joint more then twice? Reason to this is that i am having problems with my driver side ball joint. I've replaced it twice and just checked it today and it is out again. Any suggestions from you guys to what i can do? Let me know!!!!!
Old Feb 24, 2010 | 02:38 AM
ack154's Avatar
I'm over 80k and haven't replaced a thing. If you're replacing it that often there may be something else wrong.
Old Feb 24, 2010 | 02:42 AM
draxcaliber's Avatar
wow, that is extremely unusual. i was helping out a friend with a tC who hit a bad pothole and initially thought she needed a new control arm and ball joint. after speaking with my toyota service manager about it, he said that the tC's ball joint rarely if ever has to be replaced. and low and behold, upon closer inspection, he was right, the ball joint was fine. if you're on your second one, there is something else wrong with your car that is causing it to fail.
Old Feb 24, 2010 | 06:49 PM
dookie1427's Avatar
my car is dropped with tein ss and im max'd out on the front. hmmmmm..... guess ill keep replacing them every few months till i get rid of the car. good thing i've got lifetime warranty on the ball joint (o'reilly autoparts).
Old Feb 25, 2010 | 02:29 AM
that hopefully wouldn't work. you see, a warranty is a gaurentee against manufacturer defect. they'll replace it once assuming that there was a defect in the part that lead to failure. but if they see that the part is failing because your car is slammed to the ground with lowered suspension. they'll quickly wise up and call BS on you and make you start paying for them.
CombatmedicR56
Nov 12, 2020 01:53 AM
killahXB2
Mar 27, 2015 10:45 AM
TheTripleC
Jan 4, 2015 06:46 PM
fur_pig
Dec 5, 2014 12:48 PM
eric_m
79
Mar 17, 2013 12:21 AM
