lowering springs
Old Apr 8, 2007 | 09:35 PM
tc5716's Avatar
Default lowering springs
Thinking about getting a tc and probably wanna lower it with the TRD lowering springs but I was wondering if I lower it, is it possible to ever put the stock springs back in for any reason if I needed to? I would imagine there would be some cost for this, if so, how much?
Old Apr 8, 2007 | 09:39 PM
DoItBig's Avatar
Scion Dynasty
DeepSouth Scions
sIcKsCiOnS
Scion Tuners
yeah of course you can put the stock ones back on, call around and find out how much it would be, probably 200
Old Apr 8, 2007 | 09:41 PM
IcetC's Avatar
yes, you can swap the springs back and forth even with any other springs u can the only thing its kind of pain if u do it yourself and paying sum1 will cost mucho dinero so yea but what reason would u want to swap them for?
Old Apr 8, 2007 | 09:44 PM
tc5716's Avatar
The only reason I was thinking was winter. I live in an area where we get alot of snow and driving a car thats lowered in the snow probably isnt the best idea I was thinking....
Anyone drive a lowered car in the northeast?
Old Apr 8, 2007 | 09:50 PM
guitarguru44's Avatar
I have it lowered 2.4 in the front on tein stechs. Im in jersey and sometimes the snow is bad.
You will be fine on the TRD. You will have a lower center of gravity so you will handle better in the snow. Unless you plan on going offroading I dont see there being any problem at all...
Old Apr 8, 2007 | 09:52 PM
PlayinWithFire's Avatar
i do... not that big of an issue... just dont try to go plowing through deep snow. Not that the tC can handle deep snow lol.
FYI this is the wrong forum... should be in the suspension one.
Old Apr 8, 2007 | 09:54 PM
jwaggz82's Avatar
I have the TRDs and love them. The car is a little more then an inch lowered and it looks like the car should have come that way. Dont worry about changing them ...you wont be slammed like some of the guys dropping 2+inches
Old Apr 9, 2007 | 02:15 AM
hubert21's Avatar
Old Apr 10, 2007 | 03:58 AM
IcetC's Avatar
yea i actually just put on my trd springs today and wow the car is a lot lower i love it!!! still haven't driven it yet but do i have to get an alignment afterward or can i get away without one...and if so should i wait for them to settle or just jump right on it?
Old Apr 10, 2007 | 04:01 PM
jwaggz82's Avatar
Well if you get an alignment you need to get the camber links. I never got an alignment and my tires are wearing pretty even. .....which means that it cant be that off. But if you want them perfect you need to get an alignment and the camber links. People who are dropping their cars a few inches w/ other springs should get realigned. My own personal view for you since you are on TRD springs ...dont worry about it.
Also - the settle is minor w/ the TRD springs. The most they go down is maybe .2inch - Ive had my TRD springs on since day1 and have had zero problems. Just make sure ....like any lowering springs .... dont hit huge potholes. You bought into the least drop you can put on the TC so nomatter what you will be riding higher then any other people dropping their car.
Old Apr 10, 2007 | 10:01 PM
IcetC's Avatar
yea i noticed lol umm the only thing is the springs did not drop evenly on the front right side i can still stick 3 fingers in the gap and the front left only 2 you can def notice the difference do you think it happened possibly from a bad installation? or should i wait to see if it settles b/c all the others sit fine except for that one
Old Apr 10, 2007 | 10:03 PM
IcetC's Avatar
also when i was installing them i had the car half way jacked up at a time and i put a lot of compression on the front left spring for like maybe 2 hours or so, should i jack up the car again and do the same to the right side and maybe it will even out? or am i stuck?
Old Apr 10, 2007 | 10:35 PM
jwaggz82's Avatar
Thats odd - I honestly do not know the answer to that. I would start a post with the topic "uneven lowering spring job" or something and see who responds. You arent going to get a mass amount of people going to a post about lowering springs. ..... post the link here cause i would like to know the answer
Old Apr 14, 2007 | 08:31 PM
Raf's Avatar
Raf
Default Uneven Lowered TC
It's possible that you have put the front springs on one side and the back springs on the other side. I'm not sure if the TRD springs are different in drop from the back to the front but I would check it out.
Old Apr 15, 2007 | 04:32 AM
jwaggz82's Avatar
This is from trdsparks.com:
Description:
"TRD Lowering Springs lower the tC approximately 1.25”, front and rear, offering a more aggressive stance and lower center of gravity. This provides added stability in hard cornering and provides a smooth, comfortable ride. Spring rate is increased 18% in the front, and 26% in the rear over stock springs."
CapnChunk
Apr 13, 2015 04:06 PM
ScionDP
Mar 1, 2015 10:57 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
Scionxa180
16
Dec 8, 2014 04:00 PM
hydrogen
Oct 29, 2003 04:58 AM
