My Brake Pads give off a Burnt Smell!
Old Dec 31, 2009 | 04:13 AM
juzlookzfazt's Avatar
Default My Brake Pads give off a Burnt Smell!
So I purchased the StopTech Stage 1 kit from Assaultech about a month ago. I installed the Axxis pads that came with em. Two weeks later, it started giving off a burning smell. There's only one way these things go on, so what in the heck is going on?
I did a little experiment and even with light to moderate braking, the burning smell persisted. Anyone have any ideas? I don't want to lose my braking and end up in a ditch or inside a minivan with people inside of it.
__________________
Old Dec 31, 2009 | 01:03 PM
Dam262a's Avatar
do u feel anything while u brake?
Old Dec 31, 2009 | 09:00 PM
TJKASS's Avatar
Use any brake cleaner when you installed them? paint your calipers? how many miles have you driven? Also are they the axxis ULT pads? If so they are a ceramic pad so they will dust a fair bit more than OE pads and they will have a slight smell to them always, shouldnt be a burning smell tho, should just be a generally hot smell. Im thinking youre just smelling the bredding coating and machining oil on the rotors burning off.
Old Jan 1, 2010 | 02:30 AM
SFTifoso's Avatar
My Axxis ult did the same thing for about a month after I installed them. I tried braking in like the box said and they still had that burning smell after driving. They have worked fine ever since.
Old Jan 1, 2010 | 03:36 AM
Its actually a mix of burning and hot smell. There is no pedal feel really. Just the smell, even after five minutes after driving using moderate braking.
Old Jan 1, 2010 | 04:35 AM
TJKASS's Avatar
As long as the pedal feel is still there then its all good. Theres nothing that will really catch on fire down there, its just the good old smell of some new ceramic pads. Just give them time to finish breaking in, nothing really to worry about. Now if you start to feel pedal inconsistency or softness, then weve got an issue.
Old Jan 1, 2010 | 03:03 PM
I still need to bleed em and replace the rubber lines, but hopefully everything is okay. Thanks.
Old Jan 6, 2010 | 06:23 PM
silvertcgirl09's Avatar
Team ScionTific
maybe its not your brakes it can be a plastic trash bag that got stuck to the exhaust pipe
Old Jan 6, 2010 | 11:06 PM
Dam262a's Avatar
^^ random?
try driving in reverse and braking hard.. ur brakes will break in quicker
Old Jan 7, 2010 | 03:33 AM
Team ScionTific
random but that could happen cuz it happened to me so u should just take a look at the exhuast piping and u may have a plastic bag under there and when the exhuast gets hot it gives of a burn smell
dmpsk8
Aug 16, 2011 12:25 AM
poonertc
May 20, 2009 05:37 PM
THansenite
13
Mar 28, 2009 03:27 PM
kikcaffine
22
Apr 2, 2006 11:09 PM
LavaBox_v1
29
May 9, 2005 01:50 PM
