NEW! Dezod V2 Rear End links for the tC
Old Apr 14, 2008 | 05:40 PM
  #81
kanundrum's Avatar
I installed mien with my wheels off and the car on jacks as well....
Why/how would the normal consumer install them with a full load of suspension ??? unless we are as skinny as a 5 year old girl. That doesnt make sense Paul.
Old Apr 14, 2008 | 05:47 PM
  #82
paul_dezod's Avatar
Scionetics
KAD
YOU NEED FULL LOAD ON THE SUSPENSION. Simple as that. You can back the car up onto ramps, which is how did the wife's tC. SO that way I can get my fat ___ under the there.
Old Apr 14, 2008 | 05:52 PM
  #83
senseiturtle's Avatar
So, with my stockies... I should climb under there, loosen, and retighten.
I guess that's what you're trying to say.
  #84
kanundrum's Avatar
Does it apply to version 2 only ? Or Version 1 as well, and hmm we were not told this I mean to most people its obvious to lift up car take wheels off and install....
Old Apr 14, 2008 | 05:56 PM
  #85
tc4joe's Avatar
I guess you need to include instructions with the future sets you send out Paul cuz everyone (including me) screwed up the install
Lucky for me...i'm pretty thin and was able to slide underneath the car (even with TRD springs and the lip kit)!
Load does make a difference... first set didn't last a week (installed wrong i guess...on jackstands) ...this set is holdin strong so far!
Thanks Paul! been abusing the crap outta my car and the new bolts are holding steady!
Old Apr 14, 2008 | 06:01 PM
  #86
paul_dezod's Avatar
Scionetics
KAD
All endlink replacements. Regardless of version
Yes sir.
Old Apr 14, 2008 | 06:02 PM
  #87
paul_dezod's Avatar
Scionetics
KAD
Yep! Welcome man. Glad to hear. They dold up well when installed correctly.
Old Apr 14, 2008 | 06:03 PM
  #88
kanundrum's Avatar
Hmmm yeaaa i gotta check mine when i go home. Definetly need to include instructions for future reference. I hope that doesnt apply for the front, there is no way someone can get under there with full load.
Old Apr 14, 2008 | 06:18 PM
  #89
paul_dezod's Avatar
Scionetics
KAD
Try ramps. That is how we did it.
Old Apr 14, 2008 | 07:22 PM
  #90
Thankfully, most of us will be able to correct it before the parts break.
Rest of us, oh well.
Old Apr 14, 2008 | 07:24 PM
  #91
paul_dezod's Avatar
Scionetics
KAD
This can also be why your fronts keep coming undone.
Old Apr 14, 2008 | 08:27 PM
  #92
kanundrum's Avatar
So im suppose to do the fronts like those as well ? how is that even possible with a ramp lol
Old Apr 14, 2008 | 08:31 PM
  #93
It probably isn't.
Old Apr 14, 2008 | 08:35 PM
  #94
paul_dezod's Avatar
Scionetics
KAD
You need load on the assembly.
Old Apr 14, 2008 | 08:42 PM
  #95
kanundrum's Avatar
even if i set the endlinks at the same height as stock and they fit perfectly fine on the sway and the strut???
Old Apr 14, 2008 | 08:55 PM
  #96
Toyota's instructions for installing the rear sway bar DO NOT say that the suspension must be under load for end link installation.
http://zoltiz.com/cars/tc/files/tcrsb.pdf
I think this is what most people are following.
In addition, it would be physically impossible to tighten the upper portion of the front endlink after the car's on the ground (ramp), with the wheel installed. That would be some serious fanagling.
So, perhaps Dezod knows something that Toyota Techs dont?
Old Apr 14, 2008 | 09:00 PM
  #97
The front spring replacement manual also clearly shows a picture of the tech tightening it WITHOUT the wheel installed.
http://zoltiz.com/cars/tc/files/tcspringsfront.pdf
Old Apr 14, 2008 | 09:03 PM
  #98
paul_dezod's Avatar
Scionetics
KAD
Regardless of what the manual says, we have tested, proven and tried the tC on a Factory Backed Program. I will see if I can get Dan Gardner, who is the driver and chief of the Scion Racing Program, to post here....
Old Apr 14, 2008 | 09:11 PM
  #99
Then the question would shift to why would this "detail" be left out on the service manual?
That would imply that EVERY SCION DEALER installing TOYOTA-BRANDED merchandise that's further covered under WARRANTY is doing it wrong.
Hell, I just climbed under my car to install the stock parts the Dezod way. Do I have to go fix it yet again?
Old Apr 14, 2008 | 09:13 PM
  #100
kanundrum's Avatar
and you didnt tell us!!!
