Problem Removing Rear Wheel Hub
Old Mar 19, 2009 | 01:27 PM
THansenite's Avatar
Yea, you can get the stock lugs off without taking off the hub.
However, here is an update with my issue:
Spent about 2 hours working on one of the hubs a few weekends ago. I used a ton of PB Blaster along with a pry bar and big hammer. I took everything off from around the hub to have plenty of room. Despite all that, it still wouldn't budge. This thing is seized on there good. I don't even know if a hub puller slide hammer will work.
I am starting to consider taking it to the dealership or a shop and seeing if I can get them to bust the hubs loose for me. I don't trust other shops to work on my car though. I guess I could try a hub puller and give it a shot.
Old Mar 19, 2009 | 05:15 PM
Sifu's Avatar
I would imagine a hub puller to work. You will probably want one with a large slide hammer. I think you could hammer it to kingdom come with a regular BF hammer and just damage the hub to no avail.
Post updates for us as I may just pick one up for future use.
Old Mar 22, 2009 | 09:15 AM
BlkTC's Avatar
im surprised no one suggested using a heat gun... heat makes things expand.. heat it up, then smack the isht out of it with a RUBBER mallet.
Old Mar 22, 2009 | 09:58 AM
Sifu's Avatar
Heat around the sensor, brake lines, etc isn't always a good idea...
Old Mar 22, 2009 | 02:49 PM
davedavetC's Avatar
i posted at the bottom of the first page, you need to get a hub puller and a heavy slide hammer bolt it to the hub and slam the sht out of it. my hubs were rusted too, and i got it off.
Old Mar 22, 2009 | 04:43 PM
BlkTC's Avatar
that's true, but you don't have to put that much heat around it, considering those are brake lines, they go through a lot of heat.
just heat up the center then you can do dave's method. lol
Old Apr 11, 2009 | 10:40 PM
ricexizxgood's Avatar
Dave,
Where can I get a hub puller and a heavy slide hammer at?
Can I rent them?
Thanks
Old Apr 6, 2017 | 06:13 PM
chibi02's Avatar
kleecker
Jan 9, 2015 02:26 PM
Joeynenj
Nov 25, 2014 05:29 AM
Slopoke21m
54
Apr 23, 2007 12:25 AM
scionara
38
Feb 25, 2004 04:52 AM
bBOXD
28
Dec 7, 2003 07:08 PM
