Spring question
you sound like you are in the same position i was in. i ended up going with tein h-techs. ride feels almost stock until you start driving it hard. the drop is nice and gives in a nice rake. it also isnt as extreme as the s-techs. There is about 1 finger in the ront and just less than 2 in the back.
install is much easier than expected. with help from a friend, it took about 4 hours total. we split up the fronts on a wednesday afternoon and the rears on a thursday afternoon. not bad at all.
Originally Posted by tCZERO
Nice drop on that, did you install that yourself? and did you have to get alignment done? or buy anything extra?
Originally Posted by 06scionsc
I have Tein S-Techs and am a factory trained toyota and honda mechanic. I have worked at a dealership for 3 years and done numerous alignments. On S-Techs you only need to purchase front eccentric bolts which can be found on ebay for $25. You can bring in the rear with an alignment using the stock eccentric bolts installed on every tc from the factory. If you are going to spend the money on springs you should purchase a camber kit aswell. On TRD springs you will be within spec on the front and back to do a quick alignment without any extra parts. On any other springs however chances are very good you must purchase front eccentric bolts. Anytime you remove the struts from a car with macpherson strut based suspension you should do an alignment to properly compensate. This is due to the fact that your strut acts as a linkage between the frame of your car and the lower arms. Comparing a tc to your experiencees with an acura integra however is like comparing an orange to an apple. They are two completely different cars.
Eccentric bolts are thinner and harder than stock bolts, however there is an eccentric part in the center that allows you to turn the head and extend inward or outward the strut. You need one for each side on the front.
bootlgr
Jan 26, 2016 01:22 AM
viciouzgamer
Feb 18, 2015 03:26 PM
Scionxa180
16
Dec 8, 2014 04:00 PM
