Springs Help - Not sure which to get
Old Apr 10, 2007 | 05:05 PM
Moonkei's Avatar
Default Springs Help - Not sure which to get
I'm looking at the Hotchkis set, as well as the H-Tech and S-Tech...
Which is the better brand in terms of quality? I'm looking for a decent drop, atm I'm using the stock wheels also.
Old Apr 10, 2007 | 05:48 PM
sddykstr's Avatar
I like Hotchkis, very clean, nice ride.
Old Apr 10, 2007 | 05:49 PM
fatboitan's Avatar
hotchikis is a very nice drop as i am planning to get those, S-tech are lowest out of all 3 with it dropping 2+ inches and h-tech are like trd which drop about 1.5. So from highest to lowest it is h-tech, hotchkis, s-tech. Quality wise they are both good but watch out for tein that are fakes.
Old Apr 10, 2007 | 07:19 PM
Moonkei's Avatar
Thanks for the info. I'll prob end up with Hotchkis. Looking at the sway+spring on Sparks right now.
Old Apr 10, 2007 | 11:09 PM
Spect2K3's Avatar
Of those, hotchkis hands down
Old Apr 11, 2007 | 12:58 AM
Mid_Life_tC-risis's Avatar
Hotchkis setup adds a few wrinkles over Tein springs / TRD sway (which is the setup I have). From what I've read, you can't use basic spring compressors on Hotchkis rear springs - the coils are too close together. So have to either use a floor jack to compress them, or have a shop install them onto your rear shock assemblies.
Sways - Hotchkis is only sway to include a front bar along with rear. This makes for a really stiff setup - good for autox - but I imagine makes it an extra rough ride for a daily driver. The front bar is a difficult install unless you have use of a lift and a helper. You can search around for more info on Hotchkis, or folks with this setup can post up. Just so you know what you're getting into.
Old Apr 11, 2007 | 01:04 AM
Bluechualappa's Avatar
You got the order correct but the H-techs are far from TRD drop!
Old Apr 11, 2007 | 01:32 AM
fatboitan's Avatar
yea i know but it was the only one i could compare to at the moment...h-tech are way more aggressive looking
prescottn
Feb 24, 2016 11:57 PM
Itgb
Sep 2, 2015 05:18 AM
AMS13
Aug 20, 2015 07:26 PM
goatbelly
Jul 12, 2015 10:13 AM
Naughtygoose
Jul 6, 2015 09:59 PM
