Swift Coilover Replacement Springs
Old Jan 1, 2010 | 03:05 AM
jaewrek's Avatar
Default Swift Coilover Replacement Springs
I'm looking to get stiffer springs for my B&G rs2 coilovers. I've heard swift springs makes a large range of different spring rates and diamaters that can be used to replace the springs on coilovers.
I was wondering if anyone has done this and if anyone knows the diamater and length of the springs of the B&Gs so I can figure out which one would fit.
Thanks
Old Jan 1, 2010 | 07:59 AM
Ro_Ja's Avatar
Swift springs are some of the best out there. I haven't heard of anyone running them on Scions though. Good luck with your project!
Old Jan 2, 2010 | 04:29 AM
jaewrek's Avatar
^^ thanks :D
and does anyone know if the tein top hat pillow ball mouts with camber plates will fit on my b&gs? Cause I need some more negative camber up front to slam more.
Old Jan 6, 2010 | 08:54 PM
jaewrek's Avatar
I know that getting shorter springs will put more load on your shocks, and the same goes for coilover replacement springs I would assume. But if I got springs that are the same height but much stiffer, how would that affect the durability of the shocks?
Old Jan 6, 2010 | 09:12 PM
Ro_Ja's Avatar
As long as everything is the same length, having stiffer springs on your B&G's shouldn't change the life expectancy of the shocks. Several companies offer the option of varying spring rates, but the shocks remain the same. I think you should be fine.
tato63
Scion tC 2G Wheel & Tire
9
Sep 30, 2015 09:55 PM
torranosaurus
Jan 28, 2015 04:53 AM
kleecker
Jan 9, 2015 02:26 PM
fluxingnation
Dec 26, 2014 04:28 PM
Scionxa180
16
Dec 8, 2014 04:00 PM
