Two Easy Questions?
I wonder how come no one makes the control arms ? you figure you can make them stronger maybe a bit longer and have the ability to change the specs to be able to go lower and still remain the correct roll center specs to be efficient. I talked to a company that was thinking bout making them, they are the best when it comes to scion so will see what happens.
Looks like there are a couple of upper rear control arm options:
http://www.killertc.com/product.php?...cat=331&page=1
The front uses macpherson struts so there is no upper front arm, just one lower arm. The rear uses a double A-arm setup, even though the top arm is just that little guy. The adjustable upper link can be used to adjust static rear camber.
bootlgr
Jan 26, 2016 01:22 AM
