225/45/17 on stock wheels. pressure question.
i run 40 to 50 psi in my 225/45/17 because the tire is wider, and if you ran the 32 on that then the side wall wouldnt be as stiff. i auto x and i take turns fast, so that may work better for me, but i dont kno how you drive so i guess wat ever floats your boat.
when i took my wheels into the shop for a rotation, the stupid guys stuck the pressure up to 40psi all around. my car felt really unstable after that occured, i depressured them back to the stock specs, 32f and 29r. the car handled a lot better afterwards. if you have tires that are the same dimensions as the stock tires then you should use the stock tire pressure specs recommended from the factory.
kleecker
Scion xB 2nd-Gen Wheel & Tire
05-22-2016 06:10 AM
darkshadowofxdeath
12-03-2014 06:59 PM
