Lug Nuts? Special sizes or What?
the things that look like nutes is where it fits into the lug wrench. mine was alot longer than a normal socket. But anyway...It broke. Not air gun no breaker bar, just my arms turning the Scion Lugwrench. I must be strong...
for the tC there should be 20 in a pack. 5 lugs per tire, 4 tires.
off set [mm (in.)] 45 (1.
lug nut size [mm] 12 x 1.5
http://infinitipa.zoovy.com/product/KYO30885B
search for Muteki's which are made by the same manufacturer, but with a different lock design. slightly heavier because of harder metal construction.
^^ that's for the heads up. Only reason I was looking at these was because If you spray paint the lugs, the will probaby be stripped silver again once ya put the wheels back on (manually) but if its soft metal, I think I may just spray paint the lugs on the facs with a little shot of spray again after I do the rotation.
Is everything aftermarket, going to f up something, geesh.. Thx
There is a reason the removal tool is so thin. Alot of aftermarket wheels today have VERY small lug holes in them. The socket is made to fit inside the lug hole on any wheel. It is also designed to be weaker then the lugnut so that it fails before the lugnut, if it wasn't, you could have an unremovable nut from being stripped out on the outside. The designer figured you would rather the key get damaged then the nut which is perfectly logical. A few members above mentioned the inner spined lug nuts are a better design. They could not be more wrong for 2 reasons. One reason is because the center hole collects water and dirt and causes rust in the worst place. Second reason is because the nut will split before the removal tool breaks creating an unremovable nut.
WOW!!!
http://www.evasivemotorsports.com/me...de=TITEK_SPDLG
this is nice!!!!!! the hole of my wheel is soooooo small the only lug nut would fit is this:
this tuner lug has no bulky head and the lug goes inside ( no lug would fit around the lug nut because of the tight hole)
but that titek looks cool.. i might be able to use the regular lug... well.. my tuner lug is only 1.27 inch long.. and it doesnt stick out from the hole ( the hole is like 1.3 deep) but that mitek is like 2.3 inch long!!!!! YEAH BABY!!!!!! 100 for the 20 pcs.. i dont care..........
20pcs BLUE 5Zigen Lug nuts for sale!!!!!!!!!!!! BRAND NEW never installed!!!!!!!!!!!! ( they wont fit because they have the bulkyhead)
pm me for pice !!!! ( it was $150!!!)
Originally Posted by trdtcpr
so most of these lug nuts say they are for use with aftermarket wheel. Is there any good lug nutz I can use with the stock wheels?
EDIT: You can use either type of tuner lug with small lug holes. the ones with outer splines have a tool same size as the other type of lug. They both fit the same size hole.
good hey told me that titek speed lugs wont fit.. i need the inverted tuner lug nuts
((((((((((((((((( =does anyone knows where can i get some nice ones? i seen some on ebay and autozone but they are UGLY
im rolling with these... http://hopupracing.com/5zproralugnu.html
in gunmetal - i definitely recommend them they're right up there with Volks in terms of quality (a tad more $ too). good price through hopupracing.com
Originally Posted by CSOCSO
no.. he cant run on thos with stock wheels........................
JM Auto Racing
Dec 19, 2014 06:36 PM
